Surface Rust Removal with Naval Jelly
mickyd
Post by mickyd »
iclark wrote:for the potato method, I was wondering if the potatoes had to be line of sight (shouldn't need to be) or if the solution would do much inside. seems like it wouldn't be any worse than where 2 tubes were laying against each other in the ferment.
Ivan
No line of sight needed for the potato. It would work inside the tube as long as the rotting potato broth circulates into the inside of the tube. If I were doing it, I'd make sure I put some potato into the tube ID
Sunny San Diego
mickyd wrote:I used baking soda but first cooked it at 300 *F for 1 hour. The heat drives off an H2O and a CO2 molocule turning the baking soda into washing soda. Sooooooo, I guess my answer is....washing soda but homemade,
I've read where baking soda works just as well but I don't know the pro's con's if any. I wouldn't try it just because a majority or reading I've done says washing soda.
I spent a week looking for washing soda and it just ain't in San Diego. They don't wash much here:eek:
Having trouble finding it here also. Was surprised to see some folks say to use baking soda. The original information I read was very specific about using washing soda, NOT baking soda.
Perhaps someone who knows why washing soda is preferred can clue us in!:)
beeg
Post by beeg »
JPG40504 wrote:Having trouble finding it here also. Was surprised to see some folks say to use baking soda. The original information I read was very specific about using washing soda, NOT baking soda.
See post #17 & 20.
tom_k/mo
Post by tom_k/mo »
Please understand, I'm not condemning anyone here, just a question... Although I haven't done it myself, I have questions about the baking of the baking soda thing... I've seen a number of videos on YouTube demonstrating the electrolysis process that just use Baking Soda with positive results. What I've read here is that baking the baking soda removes an H2O molecule and a C02 molecule, turning it into Washing Soda, but then you put it in Water, which is H20 again... and I've read that the solution will last forever, so what is the point of removing an H2O molecule only to add it back when you put it in water... Ends up, the only thing you're actually removing from the equation is a carbon dioxide molecule (C02). Is the removal of the C02 molecule really that important to the process?
tom_k/mo wrote:Please understand, I'm not condemning anyone here, just a question... Although I haven't done it myself, I have questions about the baking of the baking soda thing... I've seen a number of videos on YouTube demonstrating the electrolysis process that just use Baking Soda with positive results. What I've read here is that baking the baking soda removes an H2O molecule and a C02 molecule, turning it into Washing Soda, but then you put it in Water, which is H20 again... and I've read that the solution will last forever, so what is the point of removing an H2O molecule only to add it back when you put it in water... Ends up, the only thing you're actually removing from the equation is a carbon dioxide molecule (C02). Is the removal of the C02 molecule really that important to the process?
You summed up my state of confusion completely! I hope we get a good answer.:)
mickyd
Post by mickyd »
I can't do this justice in the few minutes I have right now but I will address this later. Tom, your comment about the H2O molecule.... The H20 bond that is going on is down at an atomic bonding level which is different than putting the stuff in water. Best comparison I can give you is this. You are Tom. You have H20 in your body. I put you in an oven at 300 degrees for a couple days. You release all your H2O molecules. You are very different when I take you out of the oven. I then throw you in the swimming pool. Will you ever be Tom again? Definitely NOT. You have been chemically altered. Same holds true with baking soda (sodium bicarbonate) that has been chemically altered into washing soda (sodium carbonate).
Sunny San Diego
mickyd wrote:I can't do this justice in the few minutes I have right now but I will address this later. Tom, your comment about the H2O molecule.... The H20 bond that is going on is down at an atomic bonding level which is different than putting the stuff in water. Best comparison I can give you is this. You are Tom. You have H20 in your body. I put you in an oven at 300 degrees for a couple days. You release all your H2O molecules. You are very different when I take you out of the oven. I then throw you in the swimming pool. Will you ever be Tom again? Definitely NOT. You have been chemically altered. Same holds true with baking soda (sodium bicarbonate) that has been chemically altered into washing soda (sodium carbonate).
What else did Tom release while in the oven? For analogy to 'hold water' he needs to 'alter/lose' SOMETHING!:D
tom_k/mo
Post by tom_k/mo »
Mike, let me prefix this by stating, I AM NOT A CHEMIST and I will gladly bow to the greater intelligence of those that are... but I understand it is changing the Baking Soda (NaHCO3) at a molecular level, however... When added to water, baking soda DISOLVES, it is not suspended. The H20 molecule in Baking Soda would be a mute point, since when the baking soda is dissolved it would release the H20 molecule to the rest of the water, but the question I had is the additional CO2 molecule. It would be released also, leaving the Na (Sodium) molecule. CO2 in water is nothing more than carbonation, which would outgas. All I was trying to understand is how much difference there is in using Baking Soda and Baking Soda that's been baked. It seems to me that once dissolved in the water it's still pretty much the same.
PS: and I can guarantee, if you stick me in a 300F oven for 3 days, I'd give off SOMETHING.... :eek:
mickyd
Post by mickyd »
I created a separate thread to continue the discussion of electrolysis since this one is going away from it's title .....Navel Jelly.
Continue electrolysis at this thread
http://www.shopsmith.net/forums/showthr ... #post34607
Sunny San Diego
