What is your monitor resolution set at? (see instruction if need be)
What resolution is your computer monitor set at? (see instuctins if you need to)
Poll ended at Sun May 03, 2009 6:19 pm
Don't care
3
9%
Don't care
12
35%
Don't care
4
12%
Don't care
0
No votes
Don't care
2
6%
Don't care
11
32%
Don't care
0
No votes
Don't care
2
6%
Total votes: 34
reible wrote:I am running xp and I have three choices to pick from
center
tile
stretch
examples pictured below:
[ATTACH]3783[/ATTACH]
[ATTACH]3784[/ATTACH]
[ATTACH]3785[/ATTACH]
An then my current one "eye of God"
2048x1703
[ATTACH]3786[/ATTACH]
You can also use free programs like IrfanView to set wallpapers.
Thank You ED. I've been operating in the stretch mode but just found that I prefer center.
However, I still have not figured out how to put two photos side by side.
mickyd
Post by mickyd »
dusty wrote:Thank You ED. I've been operating in the stretch mode but just found that I prefer center.
Dusty - in advance mode, when you want to put two photos side by side, are you using the paper clip thing? If so, make sure that when you go to insert the second image that your cursor is directly to the right of the first image. It will look like this in advance mode
[Image 1][Image2]
You did it before. I saw it. But when I went back, you edited it and it was gone.
Sunny San Diego
mickyd wrote:Dusty - You had it. Now it's gone. Not only is whatever had gone, but when I clicked on "Quote" to reply to your message, your "Quote" text didn't appear. Are you messing with the "bowels" of the programing for this forum?? :eek: :eek:
If you are actually a seasoned hacker, transfer $1M into my checking account # 456-23454-32-1344:D :D
All I did was post to the forum and then delete the post because it did not seem to work.
Are these the shots that seemed to work?
[ATTACH]3787[/ATTACH][ATTACH]3786[ATTACH]
fixit
Post by fixit »
1280 x 1024 here. That produces the smallest text my old eyes can read. Monitor will go higher but then both my eyes and SWMBO complain! :D
Leonard
La Vernia, TX
Wood Goods - Custom Woodwork
All I did was post to the forum and then delete the post when it did not seem to work.
[ATTACH]3788[/ATTACH][ATTACH]3789[/ATTACH]
mickyd
Post by mickyd »
center
tile
stretch
2048x1703
Ed,
Take a picture of the screen with the tiger picture from my post #5 when your in the "eye of God" mode. I want to see how much of the screen the image fills up.
Sunny San Diego
mickyd
Post by mickyd »
dusty wrote:All I did was post to the forum and then delete the post when it did not seem to work.
You've got it. Don't edit this post.
Sunny San Diego
mickyd
Post by mickyd »
I have to go work on my SS. See you guys later. Glad to see the flurry of posts!!
Sunny San Diego
mickyd wrote:You've got it. Don't edit this post.
You say, I've got it. But it doesn't seem that way here.
I have the two shots but they are one above the other and not sidebyside.
The following are for educational purposes only and for that purpose only.
The following set of photos are of a copy of the tiger I found online at a resolution of 500x375.
First with screen resolution set at 800 x 600
[ATTACH]3790[/ATTACH]
Second with 1024 x 768
[ATTACH]3791[/ATTACH]
Third with 1600 x 1200
[ATTACH]3792[/ATTACH]
Forth with 1680 x 1050
[ATTACH]3793[/ATTACH]
Fifth is with the screen at 1680 x 1024 and Safari open so the whole image can be seen and then some.
[ATTACH]3794[/ATTACH]
600x800 screen 500x375 tiger.jpg (464.77 KiB) Viewed 5219 times
1024x768 screen 500x375 tiger.jpg (451.2 KiB) Viewed 5217 times
1600x1200 screen 500x375 tiger.jpg (420.47 KiB) Viewed 5216 times
1680x1050 screen with 500x375 tiger.jpg (426.06 KiB) Viewed 5214 times
1680x1050 screen safari window showing image from post.jpg (393.13 KiB) Viewed 5217 times
