Headstock Quill lever Allen Screw?
horologist
Post by horologist »
Dusty,
Great link. Now I know where I can buy sex bolts. I didn't even know they existed. This group is an educational experience!
Even more important they also have small oval head slotted steel wood screws. Only problem is they come in the convenient box of 10000.
Troy
baddlad
Post by baddlad »
SDSSmith wrote:Just to be sure.....which set screw are you trying to remove. The one on top of the headstock that retains the quill or the one on the side that tightens against the quill return spring housing?
the one that tightens against the quill return spring housing.
judaspre1982
Post by judaspre1982 »
charlese wrote:O.K. Maybe I'm getting it. By "Extended tip" do they refer to only cup tips, or do they also refer to flat and rounded tips?
This from Wickipedia -
"...Set screws appear with a variety of tip types. The different shaped tips have different properties that engineers can utilize. If an engineer were to use a detent to ensurce proper nesting of the screw, they might choose to use a cone point type of screw. One might might often need to use a flat point when the screw must press perfectly flat against a surface. The most common type is the cup point. This type works well because the surface is rounded so that a small surface area is in contact, but it does not have extremely high stress at one point like that of a cone point. Durability studies show that the cup point offers superior resistance to wear while maintaining a strong grip. [1]
Common points include the following:
Flat Point
Domed Point
Cone Point
Cup Point
Knurled Cup Point
Extended Point (Pilot Point, Dog Point) "...
I believe(not due to some knowledge I am privy to) the extended(dog) points are flat ended. Their purpose is to penetrate into a hole/slot in the material being screwed into. Examples: Slot on top of the quill shaft where the extended set screw sets in the groove and thus prevents the quill shaft from rotating. A shaft may be bored so the extended tip acts like a key when extended into the shaft. They also are made with nylon extensions(dog). I would think one of these would be appropriate for the SS quill /groove application.
billmayo
Post by billmayo »
JPG40504 wrote:I believe(not due to some knowledge I am privy to) the extended(dog) points are flat ended. Their purpose is to penetrate into a hole/slot in the material being screwed into. Examples: Slot on top of the quill shaft where the extended set screw sets in the groove and thus prevents the quill shaft from rotating. A shaft may be bored so the extended tip acts like a key when extended into the shaft. They also are made with nylon extensions(dog). I would think one of these would be appropriate for the SS quill /groove application.
The quill housing set screws I removed from later made (2000s) Shopsmith "C" headstocks has a brass or bronze tip on the them. I had been using the extended brass tip set screws as I find the steel tip ones were causing a burr along the sides of the quill housing groove plus causing a small ding on the sides of the housing groove where the quill housing was retracted/resting. I believe these dings were from vibration when the quill was not being extended.
mickyd
Post by mickyd »
Thanks for taking care of my dirty work dusty. jpg was all over me regarding the new half dog term he saw!:D
Somehow, I missed this thread continuing. I was surprised this morning when I went into it to see all the posts since I last was here. I think I need to change my system of seeing what posts are new. I usually do the "New Posts", "show firist unread" method but as I mentioned before, that isn't always reliable. You wonder, "Well if you realized it isn't reliable, why do you continue to do it!!" Answer: :o Old dog, new trick.
Sunny San Diego
mickyd
Post by mickyd »
JPG40504 wrote:..............................
BTW You might mention the Heli-coil solution requires special(expensive) tap and maybe an insertion tool(also expensive). Kinda extreme for ONE set screw, BUT it WOULD be closer to ORIGINAL!!!!!:D
OK, I'll mention it. Heli-coil solution requires special(expensive) tap and maybe an insertion tool(also expensive).
I forget, for some of us, this stuff is on our shelf. For others, it's about a $50 bill.
Sunny San Diego
mickyd
Post by mickyd »
baddlad wrote:ok yeah that was like greek to me.
Here's the greek version for you:D
Αν όλα τα άλλα αποτύχουν, μπορείτε εύκολα να τρυπάνι το, retap υπερμεγέθης και η χρήση ενός helicoil να επανέλθει με το ίδιο σύνολο βίδα διαμέτρου ή βρύσης υπερμεγέθης και χρήση τι λέγεται ένα δεύτερο σημείο που σκύλου βίδα Ή απλώς τρυπάνι και στρόφιγγα σε μια ελαφρώς διαφορετική τοποθεσία.
Sunny San Diego
[quote="mickyd"]Here's the greek version for you:D
&#913]
Notice the strange characters! Author included!:D
mickyd
Post by mickyd »
chuck - extended tip aka half dog have flat ends. They are typically used in applications similar to SS quill where it's function is to ride in a slot and prevent either rotation or acts as a stop. If it is riding in a slot (keyway) the component obviously can not rotated. It the slot has a square end, the half dog, when contacting it, will act as a stop.
Sunny San Diego
