TIP - Adjustable Story Stick
georgek1 wrote:JPG, thanks for the tip and pics. Good idea, I am sure I will be building several very soon.
George
Thank You for the thank you, but I do not deserve it. I posted NO pix! Not sure about the 'tip' either! Direct yer thanks to Gene!
Another 'thought'.(I have not actually done this) Fabricate(fancy schmancy word for 'make') a 'pointy' shaped end/plug) to insert into the ends of the telescoping extension tube support(after removing the crutch tip and pivot). This will be adjustable from about 2' to 4'. If yer really adventuresome and need a longer one, make a coupler and join more than one(even a 5' extension tube?).
navycop
Post by navycop »
I was cleaning out (edit-clearing out) the garage yesterday. I found some old adjustable curtain rods. One had a flat end on each side. I drilled a hole in the top piece then placed a thumb screw. This secures the rod at the proper dimension.
Mark V 520, Ryobi 12" mitersaw, Delta 10" tablesaw, DC 3300.
