Setscrews Used by Shopsmith
judaspre1982
RE:Nylon Motor Pan Set Screws
Post by judaspre1982 »
mickyd wrote:Where are they marked? (head, threads, point?
A spot on the threads.
judaspre1982 wrote:After some searching the SS web site and looking thru the exploded veiw of the headstock and a list of the parts in the headstock I have concluded that the set screws in ? are for the motor (fan) sheave ( I think ). When looking at the parts list there is a Motor Pan Assembly P/N 504194. It contains parts with reference #s 114-129. Ref # 118 -P/N 513056 is listed as a cup point set screw. The set screw looks like it holds the motor (fan) sheave to the motor shaft. This is all I can come up with. --Dave http://www.shopsmith.com/ownersite/part ... mbly_2.htm
My 510 has a serrated cup fan sheave setscrew with a nylon? plug(that red/black/... dot) that prevents the screw from working loose. I have noticed these 'nylock' type screws in later models(I do not recall ANY on my Goldie).
judaspre1982 wrote:After some searching the SS web site and looking thru the exploded veiw of the headstock and a list of the parts in the headstock I have concluded that the set screws in ? are for the motor (fan) sheave ( I think ). When looking at the parts list there is a Motor Pan Assembly P/N 504194. It contains parts with reference #s 114-129. Ref # 118 -P/N 513056 is listed as a cup point set screw. The set screw looks like it holds the motor (fan) sheave to the motor shaft. This is all I can come up with. --Dave http://www.shopsmith.com/ownersite/partscat/headstockassembly_2.htm
That is one of the setscrews that I recently purchased. I ordered it believing it was the setscrew buried under ackenpunky (sp) on the back side of the headstock (part of the quill feed assembly).
There is another which is part of the Motor Sheave Assembly. Neither of these are listed in quantity (5).
PS I got side tracked on the quantity (5) issue. That is the quantity in the help kit. However, coincidently, the Motor Pan is attached with quantity (5) screws. It was this coincidence that I got caught up in. Ref post #16 this thread.
judaspre1982
JPG40504 wrote:My 510 has a serrated cup fan sheave setscrew with a nylon? plug(that red/black/... dot) that prevents the screw from working loose. I have noticed these 'nylock' type screws in later models(I do not recall ANY on my Goldie).
Is nylock the proper terminology for what I have been referring to as nail polish?
mickyd
Post by mickyd »
dusty wrote:Is nylock the proper terminology for what I have been referring to as nail polish?
Nylok is actually a registered trademark brand name of a manufacture that provides nylon patch (sprayed on nylon) and pellet (machined cavity in the fastener and inserted) products. http://www.nylok.com/
The other major competitor is ND Industries. http://www.ndindustries.com/
The generic name is nylon patch or pellet.
Sunny San Diego
Think Frigidaire Dusty! I did misspell nylok! Nail polish = nylon patch.
JPG40504 wrote:Think Frigidaire Dusty! I did misspell nylok! Nail polish = nylon patch.
This technology looks great. However, it doesn't look like anything I have seen in any of the Shopsmith items I have worked on.
The Nylok website causes me to believe the product is BLUE and it appears to be engineered into the fastener not dabbed on (like nail polish).
dusty wrote:This technology looks great. However, it doesn't look like anything I have seen in any of the Shopsmith items I have worked on.
The original nylok was the 'plug' type. A hole in the side of the threads held a nylon 'plug' which protruded to about the od of the threads. What we are seing on the ss hardware is a 'cost reduced' replacement and is a 'blob' stuck onto the threads in one spot. The color can vary. I do not know if the color means anything. There are sealing type screws which are like a coating over most of the thread. The home page for ND shows that type.
In any event, the ss screws with the blob/patch/nail polish are intended to prevent the screw from coming loose when unintended. They require considerable extra torque to install them and remove them(the first time anyway).
