dusty wrote:These inputs are great but when we begin pulling information together from different sources it does get confusing. Examples being the last two posts from claimdude and JPG.
Claimdude reports that he bought his machine in 1984 and it was originally configured with a one bearing quill. Simultaneously, JPG reports that the two bearing quill was introduced in October 1984 as identified by SN 19xxxx.
All that seems OKAY but then other information gets added. I now have possession of headstock SN 152166 (May/June 1983) that has a poly-v, 1 1/8hp motor, 2 bearing quill and rough gray paint. Hmmmm...The two bearing quill and the rough gray paint seem to have been in existence before the dates indicated in the charts shown on the Shopsmith site.
http://www.shopsmith.com/ownersite/faq/markv.htm
I can only conclude that either my own data is wrong or that some Shopsmiths were produced with whatever parts/assemblies were on hand at the time and that specific configurations may be in contradiction with a strict reading of the charts.
JPG, do you have other information that indicates the 19XXXX series was used to identify the introduction of the two bearing quill or was this a logical deduction? Does 13xxxx identify the 1 1/8hp motor introduction. Do all the Goldies have poly-v? What happened in 1984 to warrant this comment in the chart referenced above? - "1984 (Gray-Rough/Texture)
(provides more spindle stability). To use this upgrade, the unit must have the Poly-V drive system".
The only thing that seems absolute is that if it is rough-gray it was produced by Shopsmith, Inc or RLFShop, LLC. All other color schemes/textures were produced by someone else.I conclude that the chart is, at best, a GUIDE to determine approximate date of production with emphasis on "approximate".
The page you referenced above is a source of some of my 'deductions'.
The reference to 1963-67 smooth gray paint coincides with Magna-American production.
The s/n for Sep 1984 lists 185359. The Oct s/n listed is 190177. I assume these be the end of month s/n. I believe they made a small number of 1 bearing quill machines in Oct with a s/n of 18xxxx and late in Oct produced 177(8?) with the two bearing quills. That would be consistent with Claimdude's experience if his s/n is 18xxxx. I doubt they made 4641(+177) units in Oct since they had been running 2 to 3k per month up to then.
I believe the 1984/rough texture reference is misplaced since the reference to poly-v compatibility. That and the "provides more spindle stability" parenthetical makes me believe the paint reference belongs in the 1972 paragraph above it. Bill Mayo posted referring to a wrinkled gray 1978 Mark V he encountered. From that I conclude SS Inc. was using different paint initially.
I do not understand the s/n 13xxxx reference. The poly-v AND the 1 1/8hp motor were introduced by Magna-American in 1962. I do not believe SS Inc made any other motor size.
Your 152166 Mark V probably was upgraded to the 2 bearing quill.
Notice the inclusion of Goldies manufactured by both Yuba and Magna American in my initial post. The earlier Yuba Goldie machines were the same as the Greenies except for color. I believe Yuba produced the later greenies. I believe only Yuba made the early goldies.
