JPG40504 wrote:FWIW one can cut either a pair of way tubes or a pair of bench tubes such that one 'half' of each is 3/4" longer than the other 'half'. Thus you get a mini set from only two previous tubes.
i.e. from one 52" way tube you get one 25 5/8" and one 26 3/8" 'halves'.
.......one 52 3/4" bench tube yields one 26" and one 26 3/4" 'halves'.
JPG,
What purpose would it be to have 4 different length tubes? I am a little confused by your comment can you clarify please?
Michael Mayo
Senior IT Support Engineer
Soft Designs Inc. albiemanmike@gmail.com
1960's SS Mark VII, 1954 Greenie, 1983 Mark V, Jointer, Bandsaw, Jigsaw, Dewalt Slider, Delta Super 10, Delta 8" Grinder, Craftsman compressor, Drill Doctor, Kreg PH Jig, Bosch Jigsaw, Craftsman Router and Table...........and adding more all the time....
Got it excuse my ignorant lack of common sense on what JPG was trying to express to me. Should have been plainly clear but sometimes the old mind just isn't there.
On another note I called Dave Ruggles in NY who sells headstock castings and had him ship me a new Type B casting to replace the one that unfortunately broke while removing the Poly V drive shaft yesterday. So I should be back in business again soon with the new Mark V. Really upset me that happened as I had no issues with my other two machines taking them apart and replacing all of the bearings but this one was definitely being obstinent and ornery. So I guess instead of backing off and taking some more time to get it out I just got mad and hit the shaft a little too hard.................DUH!:mad: I had plenty of new bearings for the quill but I have to order the ones for the Poly V drive so I am going to get the motor bearings as well and do those at the same time. The outer shell of the machine was pristine but when I got inside and started removing stuff that is when the rust started to rear it's ugly head most of which was internal to the bearings and shafts and I assume the reason I had such a hard time getting the drive shaft out without breaking the casting. Live and learn!
Michael Mayo
wannabewoodworker wrote:Got it excuse my ignorant lack of common sense on what JPG was trying to express to me. Should have been plainly clear but sometimes the old mind just isn't there.
Glad to hear that Dave was able to help you out with a casting. He's a good guy.
On the Mini tubes...my initial suggestion (cut bench tube in half, then cut way tube to 3/4" less than the resulting cut bench tube) can yield to sets of Mini tubes from one set of Mark V tubes. If you want a little more length in your Mini you will have to use all 4 tubes from the Mark V.
SDSSmith wrote:Glad to hear that Dave was able to help you out with a casting. He's a good guy.
This may be obvious to someone who has rebuilt more than one or two Mark Vs, but what happens if you just cut the way in half and then the bench in half? What does not fit right? The resulting delta is 3/16".
"Making Sawdust Safely" Dusty
dusty wrote:This may be obvious to someone who has rebuilt more than one or two Mark Vs, but what happens if you just cut the way in half and then the bench in half? What does not fit right? The resulting delta is 3/16".
Actually the difference between the 'cut' way tubes and bench tubes should be about 3/8". Which is 3/8" from the Shopsmith 'designed' 3/4" difference. This would result in the bench tubes having to be inserted 3/8" further into the headstock casting than they would normally be inserted.
This should not normally cause a problem unless you are inserting an accessory whose tubes are longer and might hit the bench tubes (such as an extension table).
I cannot afford the possibility of the interference since my Mini could end up from Canada to Puerto Rico to Austrailia (oh and any of the 50 United States).
Thanks Rob. That clears it all up for me. I recalled when I reassembled the Mark V that I built from parts and pieces that the way tubes bottom out in their receptacles while one end of the bench tubes could be inserted too far.
Actually, what happened was I built up the base arm and head rest assemblies with a pair of bench tubes and then when I attempted to install the way tubes they did not fit (too long). I had the bench tubes inserted too far.
I still wonder why that end does not have a built in stop to prevent the tubes from being inserted too far.
