Attention Lathe Turners
paulmcohen
Post by paulmcohen »
Does anyone know when the new (thicker) eccentric was introduced and what is its part number?
Paul Cohen
Beaverton, OR
paulmcohen wrote:Does anyone know when the new (thicker) eccentric was introduced and what is its part number?
Check here. I don't know when it was released but I received one of the early releases in April 2010.
The Eccentric Bushing is 515616 and in April 2010 it cost me $27.29 which is the online cost today.
dusty wrote:Check here. I don't know when it was released but I received one of the early releases in April 2010.
Tailstock eccentric Dusty!
I only know it was mentioned here on the forum that they are now thicker.
JPG40504 wrote:Tailstock eccentric Dusty!
Are you sure about that? I am unaware of a "NEWLY DESIGNED" tailstock eccentric.
The original tailstock eccentric (288) is part number 501437 Eccentric Mount and it has been replaced by 5014379 and is referred to as a Center Adjust.
paulmcohen
dusty wrote:Are you sure about that? I am unaware of a "NEWLY DESIGNED" tailstock eccentric.
What is the difference between 5014379 and 501437. When was 5014379 released and it it less likely to warp?
Paul Cohen
Beaverton, OR
paulmcohen wrote:What is the difference between 5014379 and 501437. When was 5014379 released and it it less likely to warp?
http://www.shopsmith.net/forums/showpos ... stcount=11
May we assume that the thickness shows up from the back side and would be visually different enough to notice?
The three that I have all look alike from this prospective. The other one is up-north but is the same vintage so most likely all the thinner ones.
[ATTACH]16643[/ATTACH]
robinson46176
Post by robinson46176 »
This isn't a problem I have had (yet :) ) but looking at it I was wondering if it would be either a problem or an advantage to polish the inside of the insert out like with a Dremel tool and filling the whole inside (except the the bore) with something like JB-weld etc? I'm not sure it would be solid enough to help stop distortion, it has a little flex to it even fully cured.
It would not be very hard at all to turn one out of a solid piece of aluminum or even steel for that matter. It could also be turned from aluminum and press fitted with a steel sleeve that has a setscrew seating channel in it. A number of possibilities...
paulmcohen
Before the repairs and the second set screw the points align when the pointer on the tail-stock points to 1/4. With the second setscrew I can get it to align at the mark but also at several other places depending how I tighten the screws. There is quite a bit of slop between the ring and the tail-stock.
Paul Cohen
Beaverton, OR
