Location, Location, Location :( :( :(
Very early 10E with speed changer.
I only saw one er????
Majones1
Post by Majones1 »
I wish I had more space and time, I would try to get them. I’m still trying to figure out how to get my car back into my garage after getting the two I now have. They are in Riverside, CA, which is two hours north of me in San Diego. It almost looks like there are four in the photos. In the photo showing the belts and speed changer, two look to be standing on end. In the last two photos, I see another one behind the 10ER. Still being new to this, I t’s hard for me to determine their model type without seeing the name plate.
Marc Jones
edma194
Post by edma194 »
edma194 wrote: Mon Aug 23, 2021 3:18 pm
edma194 wrote: Mon Aug 23, 2021 11:44 am
lew wrote: Mon Aug 23, 2021 11:02 am Not much detail, but for $125..
https://providence.craigslist.org/tls/d ... 34673.html
I missed an alert on that one because he spelled it as two words Shop Smith. If he still has it and the motor works I'll try to pick it up today. It's half way across the state but I think I can manage the trip.
He still has it. His power is out, he's way down in southern Rhode Island and they got hit by the storm. We got lucky way up here in the northern country. As soon as he has power back I'll go down and take a look.
Got the machine and an old Craftsman horizontal bandsaw for $100. Good enough deal for me. The Shopsmith is old but doesn't show signs of heavy use. Needs a good cleaning. It will just be spare parts though.
edma194 wrote: Wed Aug 25, 2021 5:28 pm . . .
Uh Huh. :D
edma194
Post by edma194 »
Here is a bargain, a Model 500 that got a headstock rebuild in 2016 for $200: https://boston.craigslist.org/nos/tls/d ... 84829.html
In contrast, here's a similar machine, with fewer extras shown, for $1,500: https://newyork.craigslist.org/wch/tls/ ... 75850.html
A lot of Shopsmiths have popped up on Craig's List lately. However, most of them seem to be in the laughably overpriced category like that second one.
I see the same thing happening here on the West Coast, Ed. Some reasonable priced while others must think theirs is made of gold. At times I have seen buying a new Shopsmith and related extras less expensive than buying the used one for sale on craigslist. Just because the 1981 gray Mark V is over 20 years newer than the Greenie Mark 5 doesn't make it seven and a half times more valuable in my opinion.
chapmanruss wrote: Tue Aug 31, 2021 1:09 pm I see the same thing happening here on the West Coast, Ed. Some reasonable priced while others must think theirs is made of gold. At times I have seen buying a new Shopsmith and related extras less expensive than buying the used one for sale on craigslist. Just because the 1981 gray Mark V is over 20 years newer than the Greenie Mark 5 doesn't make it seven and a half times more valuable in my opinion.
Is there any reason why I could not build up a <ark 5 casting with current version parts? Is everything compatible?
If I had done that, what would I have? A Mark xxx ??
My Shorty was built from an older headstock using mostly new parts.
We are kinda getting away from bargains here but your questions and their answers may be helpful to buyers looking to buy Shopsmith tools.
Dusty, you asked,
Over the years changes for the Mark 5/V have been made backwards compatible so you can have a Mark 5 "A" Headstock from 1954 or 55 with current parts in it. Some can be changed individually while others as assemblies. You can replace the quill return spring with the current one going back to even the first Model 10E's. One change may necessitate another such as changing from a Gilmer Drive to the Poly V Drive also requires changing the Quill Assembly. Upgrades can be made to the Mark 5/V such as the Table System or Power Pro DVR Motor.
Dusty you also asked,
If you only make changes to the headstock it would still be the same Mark 5/V model as all Mark 5/V Model's use the same headstock. If you change a Mark 5 or V with the original table system to one of the larger Table Systems of the 505, 510, 520 or Mark 7 what would it be called? I have a Mark V 520 that has been completely upgraded to a Mark 7 which is what I commonly call it even though the serial number (date code) on the headstock is 09-11-01 and the Mark 7 came out in 2010. You can see that in the list under my name below. That headstock is one I put together with the parts that came with the Power Pro motor upgrade and purchased parts including a "C" headstock shell. I kept the original headstock as a spare/backup. The Mark V 520 listed below was originally a 2006 Mark V 505 in which tables have been upgraded. For the Mark V it is the difference in the Table System that makes it what model it is but it is helpful to know it's history. A lot of information about that can be found at the link below.
viewtopic.php?f=7&t=24963
edma194
Post by edma194 »
dusty wrote: Tue Aug 31, 2021 1:20 pm Is there any reason why I could not build up a <ark 5 casting with current version parts? Is everything compatible?
One simple but pricey step is to upgrade a Greenie headstock to a PowerPro. The upgrade kit comes with a new quill and everything else you need. I drilled and tapped a hole in the casing for a retaining washer to hold the eccentric bushing instead of relying on the cast in clamp on it's own. Too much pressure on the clamp can crack the casting.
edma194
Post by edma194 »
Here's a pretty good deal if you want the accessories it comes with, especially the Ring Master and Belt Sander. $400 is a fair price although I'd try to talk it down:
https://syracuse.craigslist.org/tls/d/f ... 11908.html
I was going to show a fantastic deal, a noce looking Greenie for $150 and the guy was willing to deliver it, but the listing is gone already. No surprise that was gobbled up.
