DLB
Post by DLB »
rlkeeney wrote: Sat Jan 08, 2022 4:35 pm Will the base assemblies from this Greenie work on a 1980s Mark V?
I have enough parts to make another Shopsmith except for one of my castings is broken.
The Greenie Bench (lower) tubes are a larger diameter, so the castings are different. So, Yes*. They will work if you also use the bench tubes. Or depending on which casting is broken.
rlkeeney
Post by rlkeeney »
DLB wrote: Sat Jan 08, 2022 5:04 pm
Thanks
Robert Keeney
Tallahassee Florida USA
The significant greenie differences include the bench tubes being 1 7/8 rather than 1 3/4. The base(end) castings differ so as to accomodate the larger tubes. By using a small spacer with 1 3/4 tubes the c-c spacing can be maintained if necessary(not all that important imo).
The way tubes etc. are the same all the way to the M7.
edma194
Post by edma194 »
10ER Shaper-Router Fence? I don't have much knowledge of 10E accessories and never heard of this but it does look cool.
It's for sale on eBay:https://www.ebay.com/itm/275102705440?m ... nl%3Dmkcid
It is the Jointer-Shaper Fence for the Model 10E and 10ER that replaces the Table Insert when using it. The downside on this one is the missing clamp, washer and wing nut that holds it to the Table. In the first picture the left side set is there but the right side set is not.
The missing clamp should be fairly easy to make and the wingnut is replacable(albeit of lesser substance).
A jointer cutter would be a nice addition.
edma194
Post by edma194 »
This one is a certainly a bargain, a Model 500 for $50: https://vermont.craigslist.org/tls/d/es ... 88889.html
Looks like serial #150699 from 1982. May not come with anything not shown in the picture but a great deal for parts or a 2nd machine.
Interesting 'second' table.
edma194
Post by edma194 »
Free 10E available: https://providence.craigslist.org/tls/d ... 48968.html
Looks pretty good for the price.
edma194
Post by edma194 »
edma194 wrote: Thu Jan 20, 2022 2:24 pm Free 10E available: https://providence.craigslist.org/tls/d ... 48968.html
The ad is still up. If someone doesn't take that thing I'll be forced to go get it myself.
