Shopsmith Large Format Drawings, Illustrations and More
HopefulSSer
Re: Shopsmith Large Format Drawings, Illustrations and More
Post by HopefulSSer »
Maybe someone else mentioned this in this very long thread but I have discovered that if I am signed into my gmail account, trying to access your google drive tells me I don't have access and to request it from the owner. However if I'm not signed in, I can access it just fine. Weird. I mention it only to help anyone else who might run into the same thing...
Mark V 510 51-014654
HopefulSSer wrote: Mon Oct 18, 2021 5:39 pm Maybe someone else mentioned this in this very long thread but I have discovered that if I am signed into my gmail account, trying to access your google drive tells me I don't have access and to request it from the owner. However if I'm not signed in, I can access it just fine. Weird. I mention it only to help anyone else who might run into the same thing...
FWIW, that does not happen here. I am logged into my Gmail account and I just accessed Everett's Google drive.
everettdavis
Post by everettdavis »
I don’t know what created problems for some but not others. Is this still happening to anyone?
I would have thought it was a Google issue. Perhaps they did something to change security.
I did go into the drive by following the link in the forum, then copied the link it took me to and updated it in the two links recorded in the post
It appeared to be the same link that was there before though.
Maybe Google has done something to enhance security and maybe embeds some sort of link dates to enhance security for logged in users.
I just don’t know. Why it worked for some and not others may be an operating system/ patch that Microsoft had rolled out to some computers and not others
everettdavis
In answer to some who have contacted me privately, yes I am fine, full of energy and have numerous projects I am restoring.
Southbend metal lathe, Bridgeport milling machine, 3 phase power to shop.
I hope to resume my Shopsmith work this year even utilizing the machine shop gear I am working on. My late friend and Mentor Bill Mayo and I postulated such a time in my future.
I still work on some highly selective document restorations, but with many of our colleague's help here, we have accumulated quite a cache of them already in the My Google Drive link in the first post in this thread. All are free to download and donated to the world wide Shopsmith community.
Blessings to everyone, and thanks for asking about me.
If my life was an LP record before I retired, I blew by 45 and went to 78 ever since.
I don't sign in unless I have something to post, and of late someone, often several of you have answered new questions before I see them. That doesn't mean I'm not here browsing after the fact!
So glad to hear that.
everettdavis
Ryan Winnicki posted on Vintage Machinery 10-25-2024 Mark VII updated Cam Control Drawing that some may really benefit from. It's Under the Magna groups of files there.
When I get time I will add it to My Google Drive Documents in the '1960's Mark VII' folder. You can download it here if you need it.
Thanks Ryan.
Cam Control Placed on Vintage Machinery 10-25-2024 by Ryan Winnicki.png (106.28 KiB) Viewed 160979 times
Maurice
Post by Maurice »
NICE! Exactly waht I was hoping to find.
FYI - I found another excellent collection of documents
https://www.dropbox.com/scl/fo/xhqjvgq6 ... ttu75&dl=0
Many documents appear novel, I did a quick spot check, drum sander, featherboard, bandsaw, biscuit, auxiliary ... everything shows lots of new matches.
For now I'm storing both independantly on my own drive. I can re-organize/de-dupliate if you like.
Just for reference, and for Google Search hits in the future, here are the docs in that dropbox, if that link ever died, I can share my own copy of them:
Code: Select all
Sharpening Woodworking Tools Part 2.pdf
Sharpening Woodworking Tools Part 3.pdf
Sharpening Woodworking Tools Part 4.pdf
Sharpening Woodworking Tools Part 5.pdf
Sharpening.pdf
Shopsmith 510 Review.url
Shopsmith PowerPro Upgrade.pdf
Shopsmith PowerStation Instructions.pdf
Smart Motor Service Carton and Packaging Step-by-Step Packing Instructions (for 516645).pdf
Speed Chart.pdf
Strip Sanding.pdf
Table Extension.pdf
Table Saw - Joinery.pdf
Table Saw - Molding.pdf
Table Saw - Special Operations.pdf
Thickness Planing.pdf
Understanding Lumber Grades.pdf
Universal Tool Rest.pdf
Veneering.pdf
2-5-16 x 6 Inch Drum Sander Extended Vac Attachment Instructions (for 556269, 556268, 556257, 556265).pdf
2-5-16 x 6 Inch Multi-Sand Drum Sander Assembly Instructions (for 556254, 556253, 556251, 556250, 556252).pdf
3-Lever Drill Press Quill Handle Instructions (for 555491).pdf
4-High Stacking Featherboard Assembly Instructions (for 556237).pdf
5-8 Inch Keyless Drill Chuck Instructions (for 556273).pdf
42 Filter Hood Hardware Pack Literature and Template (for 555942).pdf
500_Summary_Manual.pdf
505-510_Summary_Manual.pdf
520_Summary_Manual.pdf
845639-FREE.pdf
Adjustable Collar.pdf
Adjustable Fitting Instructions (for 557055).pdf
Adjustable Stop Collar Literature (for 555937).pdf
Auxiliary Spindle Shaft Guard Instructions (for 521889).pdf
Bandsaw (Older Model Cast Iron Table) Owners Manual and Reference Guide.pdf
Bandsaw Blade Back-Up Bearing Upgrade Instructions (for 555074).pdf
Bandsaw Dust Chute Literature (for 300000).pdf
Bandsaw Fence Literature (for 555645).pdf
Bandsaw Owners Manual and Reference Guide (for 555943).pdf
Bandsaw Table Extension Literature (for 555488).pdf
Bandsaw Table Retrofit, Extension, and Circle Cutter.pdf
Bandsaw Tire Service Literature (for 518108, 555644).pdf
Bandsaw.pdf
Belt Sander Dust Chute Upgrade Instructions (for 300002).pdf
Belt Sanding.pdf
Biscuit Joining.pdf
Biscuit Jointer.pdf
Caster Bracket (Standard) Instructions (for 555354, 514149, 513102).pdf
Chisel Sharpener Attachment Instructions (for 555812).pdf
Circle Cutter.pdf
Conical Sanding Literature (for 555435 + 555477).pdf
Conventional Smart Motor Drive Belt Installation Instructions (for 521682).pdf
Conventional Smart Motor Packing Instructions.pdf
Crosscut Auxiliary Table Literature (for 555526).pdf
Crosscut Sliding Table Instructions (for 516524).pdf
Dado Safety and Operating Instructions.pdf
DC-330L Dust Collector Owners Manual and Reference Guide (for 523171).pdf
DC-3300 Dust Collector Owners Manual and Reference Guide (for 300002).pdf
DC-6000 3300 Dust Collector Service Switch Instructions (for 556091, 556455, 522388).pdf
DC-6000 3300 Front Handle Upgrade Kit Instructions (for 521769).pdf
DC-6000 3300 Hose Valve Assembly Instructions (for 555468).pdf
DC-6000 Owners Manual and Reference Guide (for 556700).pdf
Dial Indicator Alignment Gauge Assembly Instructions (for 555884).pdf
Disc Sander Dust Chute Assembly Instructions (for 555167).pdf
Disc Sanding.pdf
Double Tilt Base Upgrade.pdf
Double Tilt Under Table Routing Shaping Instructions (for 556210).pdf
Drill Press.pdf
Drum Sander.pdf
Drum Sanding.pdf
Dust Collection.pdf
Dust Collector Fan Instructions (for 515287).pdf
Dust Collector Handle Upgrade (for 521769).pdf
Dust Collector Wheel Supplement (for 556455).pdf
Edgewood Safety Device Instruction Sheet.pdf
Eliminator Chuck Literature (for 556451).pdf
Everything you need to know about Sanding.pdf
Extra Flip Stop Literature (for 52170803, 52170802, 52170801, 556005).pdf
Face-Plate Turning.pdf
Featherboard Hold Down Assembly and Instructions (for All MARKs except MARK V 500) (for 555783).pdf
Featherboard Hold Down.pdf
Fence Flip Stop, Rail Assembly Instructions (for All MARKs except MARK V 500) (for 555807).pdf
Glossary of Terms.pdf
Grinding Wheel Guard.pdf
Horizontal Boring & Doweling.pdf
Infeed-Outfeed Extension Table Brackets.pdf
InstallPwrSwitch.pdf
Jointer Auxiliary Fence Assembly Instructions (for 555653).pdf
Jointer Feather Guard Upgrade Literature (for 555480).pdf
Jointer Feather Guard Upgrade Template (for 555480).pdf
Jointer Fence Mounted Featherboard Assembly Instructions (for 555654).pdf
Jointers.pdf
Jointmatic Owners Manual and Reference Guide (for 555458).pdf
Kreg Precision Bandsaw Fence Literature (for 556030).pdf
Lathe Duplicator Cutter and Followers Literature (for 555278, 555213).pdf
Lathe Duplicator Owners Manual and Reference Guide (for 555638).pdf
Lathe Duplicator Steady Rest Instructions (for 555639).pdf
Lathe Duplicator.pdf
Lathe Turning.pdf
Lift Assist (MARK V after 1972) Literature (for 555975).pdf
Lift Assist (PowerPro MARK 7 MARK V after 1972) Literature (for 556191).pdf
Lift Assist Replacement Cylinder Upgrade Instructions for PowerPro Smart Motor (for 556199).pdf
Magna_Jigsaw_Manual.pdf
MARK 4 (Shorty) Owner’s Manual (for 557400 + 557400P).pdf
MARK 7  MARK V 520  MARK 4 Floating Extension Table Instructions (for 555984, 522356, 556187).pdf
MARK 7 Owners Manual (for 556187).pdf
MARK 7 Power Cord Replacement Instructions (For 513970 + 517319).pdf
MARK 7 Table Height Crank Handle Supplement (for Parts on MARK 7 Carriage).pdf
MARK 500 Extension Table Top Upgrade Instructions (for 555085).pdf
MARK Self Study Course.pdf
MARK V 500 Logo Cover Replacement Instructions.pdf
MARK V 500 Lower Saw Guard Upgrade Literature (for 555294).pdf
MARK V 500 Miter Slot Guide Bar Assembly Instructions (for 516525 + 516619 + 555895).pdf
MARK V 500 Tie Bar Assembly Literature (for 504247).pdf
MARK V 500 To 510 Floating Extension Table Upgrade Instructions (for 555137, 555136, 555924).pdf
MARK V 500 To 510 INCRA Floating Extension Table Upgrade Instructions (for 555936).pdf
MARK V 500 to MARK 7 Pro Fence & Table Upgrade (For 555985).pdf
MARK V 505 to MARK 7 Pro Fence & Table Upgrade (for 555986).pdf
MARK V 510 to MARK 7 Pro Fence & Table Upgrade (for 555982 MARK V 510 made in 1986 or after).pdf
MARK V 510 to MARK 7 Pro Fence & Table Upgrade (for 555983 MARK V 510 made prior to 1986).pdf
MARK V 520 Rear Support Table Conversion (for 521651).pdf
Mark V 520 Rip Fence Upgrade.pdf
Mark V 520 Upgrade Package.pdf
MARK V 520S Owner’s Manual (For 557501, 557500).pdf
MARK V Accessory Hub Literature (for 555124, 505631).pdf
Mark V Alignment and Maintenance.pdf
MARK V Motor Replacement.pdf
MARK V Power Cord Literature (For 518289 + 556492 + 517127 + 517318).pdf
MARK_7_Summary_Manual.pdf
Miter Bar Literature (for 518104).pdf
Miter Extension Literature (for 556005).pdf
Miter Gauge Instructions (for 505700).pdf
Miter Gauge Safety Grip Instruction Sheet (for 505625).pdf
Miter Gauge Stop Rod Literature (for 505629).pdf
Miter Pro Owners Manual (for 555404).pdf
MKV_supplement.pdf
MKV500_SuppInfo.pdf
MKV510to520UpgradePkg.pdf
MKV520_RipFenceScaleUpgrade.pdf
MKVMotorReplacment.pdf
MKVPacking_for_shipping.pdf
MKVShaftGuard.pdf
MKVSTDPartsList _1_14.pdf
Mortising & Tenonning.pdf
Mortising System Manual (for 555810).pdf
Mounting Base Instructions (For 505655, 522434).pdf
Mounting the Smart Motor on the Way Tubes Instructions (for 556176, 522400, 556178).pdf
Non Slip Surface Literature (for 516348).pdf
Non-through Cut Riving Knife.pdf
Oscillating Sander Gear Change Instructions (for 521592).pdf
Oscillating Sander Literature (for 555754).pdf
Overarm Pin Router.pdf
Pattern Sanding Guide 3-Piece Package Literature (for 556238).pdf
Pattern Sanding Guides.pdf
Planer (MARK Mounted) How to Use on PowerPro Smart Motor Instructions (for 514056, 516073).pdf
Planer Dust Chute Instructions (for 555643, 300001).pdf
Planer Jointer Knife Sharpening Jig Literature (For 555471).pdf
Poly V  Gilmer Belt Literature (for 521683, 521681, 556490, 556492).pdf
Power Station Owner’s Manual and Reference Guide.pdf
Power Station Switch Instruction Sheet (for 522387, 518060, 556452, 518053, 515752).pdf
Power Tool Woodworking for Everyone 1955.pdf
Power Tool Woodworking Reference Guide.pdf
PowerPro GFI Supplement Instructions.pdf
PowerPro Smart Motor Owner Manual and Reference Guide (for 556176).pdf
Premium Casters Installation Instructions (for 556247 + 556224).pdf
Premium Casters Literature (for 556247 + 556224).pdf
Pulley Guard Instruction Sheet (for 505862 + 522434).pdf
Rip Fence 500 845363.pdf
Routing Slot Mortising.pdf
Routing.pdf
Sawdust Sessions.url
Scroll Saw.pdf
Shaping.pdf
Sharpening Woodworking Tools Part 1.pdf
Cheers mate! :)
1983 Mark V 500 (230V/50Hz AU) S/N SS-115073
11" Bandsaw (incoming)
Brisbane, Australia
