Share your Magna memorabilia!
I have seen them on eBay a few times. Not common at all.
jpdalton
Post by jpdalton »
chapmanruss wrote: Sat Mar 04, 2023 12:25 pm I have a 10" double-sided Sanding Disk which is shown below.
I’m curious whether Magna intended this to be a double sided sanding disc, or whether the slight conical shape is instead intended to provide rigidity on a non-abrasive side of the disc. Is it aluminum? The lack of sandpaper cut for conical use in their accessories catalog may indicate it was intended only for use on the flat side.
John Dalton
Massachusetts
1948 10E, S/N 5052 (restored)
1952 10ER, S/N 51721 (restored as dedicated drill press)
1954 Mark 5, S/N 263334 (functionally restored)
c1959 Mark 2, S/N 81940 (undergoing restoration)
"Modern Power Tool Woodworking" (Mark VII PTWFE) does not mention attaching paper to the backside of the 10 " aluminum disc.
It does however describe tilting the table to be square with the tapered backside(1 1/2°) and using the fence, it alleges the ability to sand to width with square edges.
I say alleged since I do not see that as working. I see that as creating an out of square edge by 1 1/2°. That creates an error of about 0.020" over 3/4".
Likely that was then considered "close enough".
I can attest to the success of attaching a 10" sanding disc to the tapered back side. However correctly creating the hole and slot that allows the disc to become a cone shape is critical.
It was not until today that I realized that was not the original intention back then.
BUT, It does work if you do not mind cutting 10" abrasive discs that are peel and stick!
On page 41 of the Mark VII manual Everett restored begins the Disk Sanding section. It begins with the following,
10" Double Faced Sanding Disc - One side conical, other side flat. Affords 78 square inches of sanding area. Attached directly to main or upper auxiliary spindle.
Further down the page it goes on to say,
MOUNTING
The SHOPSMITH 10" disc can be used on either the main spindle or the upper auxiliary spindle. On the main spindle it can be flat face out or with coned face (hub side) out. Either way around it may be used with the accessory lower saw guard in place for dust collection. On the auxiliary spindle the disc can be mounted only with the flat face out.
Now why did it take so long to have a Lower Blade Guard large enough to have dust collection for the Mark V? Of course, I refer to the 1985 introduction of the Mark V 510/505 which the Lower Blade Guard which can be used with the 12" Steel Sanding Disk. This is the reason the 12" Steel Sanding Disk needed a longer Hub.
Backing up to page 8 under STANDARD ATTACHMENTS I refer to item 15,
(15) - Sanding disc - Double sided 10" sanding disc; one side flat and one side tapered for greatest versatility. Attaches to
spindle---balanced for vibration-free operation.
All SPT's & 2 Power Stations
jpdalton
Post by jpdalton »
Model 10E Preliminary Owner’s Manual from S/N 7127
jsburger wrote: Sat Apr 30, 2022 7:27 pm Here is probably the rarest of the Model 10 items. It is an original preliminary Model 10E owners manual.
Very pleased to have been able to add something rare (but apparently no longer unique) to my collection this week.
This is a well used manual for sure! The cover sheet is a little rough as a result, but overall pretty good for something 75+ years old that spent its time in a craftsman’s workshop.
Something that is unique about it is this…
A 24th page that contains the master parts list! Given that these were held together with a couple of staples, it’s understandable that the last page could have been ripped off the back of Mr. Burger’s much cleaner copy of this document without it being noticed.
One more important detail that I’ve been able to determine from this document is its provenance. This was included with the purchase of Serial Number 7127 - far later than one of the original 250-unit order with which it has been assumed these preliminary manuals were exclusively shipped. Also I was able to see the name of the original owner (from one of the other system documents), who I assume acquired this in Indiana, where he lived at the time.
I also know where he bought it!
John Dalton
Massachusetts
John,
You said,
I would guess Montgomery Wards or at least he looked for accessories there.
jpdalton
Post by jpdalton »
chapmanruss wrote: Sun Mar 12, 2023 6:04 pm I would guess Montgomery Wards or at least he looked for accessories there.
I’ve seen this same set of accessories documents without the Montgomery Ward branding. They came with my Model 10-E S/N E5052 (see below), which I know was purchased at an independent retailer. So I suspect these 5 sheets were part of the early document pack included with any system purchase, and at least indicate whether or not the machine was sold by MW.
John Dalton
Massachusetts
jpdalton
Post by jpdalton »
A Mark 2, or a Mark 5?? Decisions, decisions…
Here’s a late 50’s Montgomery Ward fold out brochure that features both the main 5-in-1 tools in their portfolio: the Mark 5 and the Mark 2. Interesting to see how they positioned each respective machine. That extra $100 to spring for the better Mark 5 system over the Mark 2 was a big decision at that time, I imagine.
John Dalton
Massachusetts
It is interesting to note that the Mark 5 is the tool showing the 5 functions. Lower cost is likely the driving factor for those choosing the Mark 2 over the Mark 5.
I believe the chart was intended to apply to both models.
