I wish I had good news to post about my vases but I don't--at least for one of them. I should have updated sooner but was "depressed" with my initial results at turning the inside. Chris, James and jdramsey were all correct in their observations of the inherit weakness of my lined up joints. I do have a Talon chuck with large jaw capabilities (more on that later) which I used to mount the vase. I did not get very far into the rounding out the inside before by gouge catch and it went to pieces. Several notes here: I sawed the segments and first glued the segments long grain to long grain to get the vertical height. There were no fairlures in any of those joints i.e. horizontal axis. In fact I had fractures in the wood itself but not the glue joints. The vertical--end to end grain joints proved to be the undoing. Possiblly because I did not "joint" the parts after sawing meaning that there were not smooth surfaces to glue. It also appears that a lot of the glue got absorbed by the end grain and therefore starving the joint. And yes I believe I recall Drew mentioning applying more glue to end grain after the initial application, a lesson I won't forget. That along with not being a seasoned turner and possibly lacking the proper lathe tool(s) all resulted in pieces for the scrap bin.
Now about the Talon chuck: I used the large jaw "accessory" with 4 of the rubber buttons attached. I had previously squared up the top and bottom of the vase while the vase was mounted between centers. I had much difficulty getting the vase to run true when mounted to the Talon. Anyone tell me why it did not run true (wobbled at non supported end)?
In the meantime I ordered and received (like in two days from SS) a set of bowl turning and spindle turning lathe tools that came on sale at the oppurtune time. I'm also trying to get into a basic turning class that I found out about today.
The second vase I have successfully turned the outside but have decided to use a microplane shaper to round out the inside. Initial tries have shown to be faster than using a drum sander and less dusty besides. Shaping with the grain makes the shaper quite effective. FYI
Regards,
Dwight
