Jigsaw
delong94
Seal
Post by delong94 »
Is it worth the effort to replace the air pump seal in the older jigsaws? I am still working on cleaning mine up. I was able to get some parts from Bill Mayo and I saw the pump seal is available on the SS website. When I power up the saw no air is pumped out.
Have you saturated the piston leather with oil?
There are ball valves at the bottom that can get gunked up.
joedw00
Post by joedw00 »
rpd wrote:I don't know where you can buy one but there is a video on YouTube that shows how you can make one that looks a lot stronger than the original.
ShopSmith jig saw repair
I just repaired mine see it here
Joe
Being a VETERAN is an honor
Being a GRANDPA is priceless
delong94
Post by delong94 »
I did put some oil down there, but it's not working. To my knowledge, this saw sat for some time (a few years) before I got it. I replaced the oil in the bottom housing. I just can't seem to get the blower thing to work.
sanipod76
Re: Jigsaw
Post by sanipod76 »
Hello,
I am looking for the lower jaw assembly for the 18" jigsaw. The unit I have will only hold blades used with portable hand held jigsaws. The parts that hold the thin scroll saw blades were missing.
Thanks for your assistane whether you can help or not!
Sanipod
rcoder
Re: Jigsaw
Post by rcoder »
Gosh this post seemed to disappear and now is up front. I gave up on the jig saw and worked a deal of sorts with a local contractor and former student for two older scroll saws he was willing to part with. One is a Delta two speed with some surface rust (now clean) and a Skill variable speed. Both do a respectable job and I am now scrolling for Christmas.
Re: Jigsaw
sanipod76 wrote:Hello,
Sanipod
Hi,
Welcome to the forums!
I own one of the jigsaws and so far as I know there is only one lower jaw, it holds "jig saw" blades as well as scroll saw blades, files, and sanding sticks. If you could post a picture of what you have we can then determine what you have and if you are missing anything.
brianvw
Re: Jigsaw
Post by brianvw »
I also used that part number and received the gaskets from Shopsmith a couple days ago. They do carry them.
hobbies
Re: Jigsaw
Post by hobbies »
does anyone have the plastic part that makes the blade go up and down dont have part number its on 18 inch shopsmith jigsaw
