You are exactly right that there is no hard stop. Without this I am finding it impossible to get secure tightening without slop. I am pondering solutions to this. Open to ideas.JPG40504 wrote:Weight(balance) is different, but the non-centered screw/tapered spot facing should pull the slop out regardless. However you will need to push the vertical stuff towards the rear while tightening the screw. Since the weight is no longer an 'over the center' condition secure tightening is required.
What is missing is a hard stop in the direction opposite of 'normal'. The cg is pulling in that opposite direction. Normally the cg is over the vertical center and the weight is pressing the hinge against the hard stop. The screw merely prevents the vertical stuff from tilting backwards back over the center.
My 'normal' table tilts towards the operator in vertical drill press setup.Nev mind, I misunderstood!!! See above.
I was unclear about the table tilting toward you- I was thinking of the whole shooting match tilting toward you.
tc
