Afternoon with Bill and Ann Mayo
SDSSmith
Post by SDSSmith »
JPG40504 wrote:Lovejoy is a 'contingency' plan!]P.P.S. "I questioned your premise of using one set of way tubes to generate a mini of 'normal' dimensions. Doing that would create bench tubes of 26" length and way tubes of 25-1/4" length."
I never said 'that!'
[/SIZE] Again: 52 - 26 5/8 = 26 3/8 = one way and one bench tube of 'normal' mini length(i.e. same as yoruns). BTW what starts out as a tube of 26 + 25 1/4 = 51 3/4 length??? ;>}
I must have misread post 26 of this thread.
Rob in San Diego
joshh
Post by joshh »
If you cut your tubes too short, you can use the coupler that is inside the Shopsmith speed reducer ( 515798 )
It mounts to the spindle on one end and accepts the 5-spline hub on the other. I think it's about half the length or less than the standard coupler.
*images borrowed from pieceseeker*
- 1986 Mark V 500 Mini
- 1985 Mark V 510 with reversible motor, bandsaw, jointer, and double-tilt.
I offer quality motor reversal, rebuilding, and rewiring. Contact me at HarbourTools@live.com
