Dusty, I just looked at your specs, and have a few ideas.
See if you can get a running motherboard/CPU/memory setup, with only an optical (CD or DVD) drive. It needs to boot into BIOS. (OK, keyboard, mouse power supply and monitor, too.) Don't assemble it in a case, but on a clean kitchen towel. (Just the mobo.)
Now, you've got a test-bed. Put a copy of Windows in the optical drive, and hook up one of your questionable HDDs. See if you can install Windows.
A bad HDD (hard disk drive, for those that aren't computer hardware aware) won't ruin a computer. At the most, it will prevent it from booting up. Usually, a Windows install just won't see it.
Oh, most people don't know, but the power supply (PSU) is a VERY CRITICAL component. In a pre-assembled (Gateway, E-machines, or white-box generic) computer, these are the cheapest available! Unfortunately, unlike a HDD, when a PSU goes bad, it can take EVERYTHING with it. You can find good PSUs, reasonably, and BAD PSUs at Caddy prices. (Just like the ER and the MkII)
steve
It Has Been Good Working With You
