algale wrote:... to start with the best alignment you can get in order to avoid problems and the need to frequently realign.
And if you have one of those Shopsmiths that some members report having that loses another few thousandths of alignment every time they look cross-eyed at it, the importance of starting with excellent alignment would seem obvious to me.
... I break mine out only when I've got a result (burning/pinching/cutting on the back side of the blade) that suggests...
So I've been reading all this and realized it is with a different mood than usually afflicts me when considering this topic. I'm not on the edge of anger this time. Why, says I. I go back to the last major table alignment I did, and now I remember. (Btw, 520, 4 large trunnion holes.)
I went in to fix it, not to try and make it acceptable. Started by loosening all, and shifting to enable access to that one semi-blocked rail nut. Lost a little "slop" but there's enough left.
[I had already removed everything, smoothed down all the contact points (they were
not good) including washers and added a layer of (hold onto something!) grease to the contact surfaces only, reassembled.]
So, all four light-finger-tight, then the standard procedure, snug the pivot, yada yada, and checking align with every breath. Any move was made in both directions until it settled. Snugged, then tightened, then
tightened, checking with every move.
I'd been "sneaking up on" each bolt- a little tap, then a little more, etc., in the same direction til I hit 'zero'. The tighten a bit and watch it go back bad. This time I tightened a bit then beat on that dang table until it did NOT move.
Haven't touched it since.
Smoothing those pieces and adding the grease made it work. It aint smooth, but it's workable.
Btw, has anyone, in the history of the earth, ever come upon a worse mechanical incompatibility than the bolts SS uses with their various castings?
(Disclaimer: yes, I did exaggerate for effect.)
