Ring Master, the questions
Since I was using scrap materials for these projects this piece had a notch cut which I knew I'd have to deal with at some point. I had a bit of a cut off from a piece of walnut so I planned it to thickness then stuck in the kerf, so now it is a nice detail to the piece. Again this is oak and has an oil finish.
[ATTACH]24483[/ATTACH]
The sharpener was sanded and then finished in oil as well.
[ATTACH]24484[/ATTACH]
So that is that.
delong94
Re: Ring Master, the questions
Post by delong94 »
I just got a ringmaster and am figuring out the angle setting. Can you post the spreadsheet you use or send me a copy? Thank you.
delong94 wrote:I just got a ringmaster and am figuring out the angle setting. Can you post the spreadsheet you use or send me a copy? Thank you.
Right now I can't find the paper copy or the computer file..... It could be I used my laptop to generate the file in which case it might be a while before I can recover it. I have the back up but the laptop died and unless I replace it or decide to attempt recovery to one of my other machines it doesn't do me much good.
I will have to dig through a box or three of papers from back then to see if I can find the paper copy. I guess I'm saying it might be a while. Sorry.
