Mark VII as a router table
cooch366
Reference to table for mounting 3hp router pics
Post by cooch366 »
Yes Ben I am back :( And not too happy about it!
http://www.shopsmith.net/forums/showpos ... stcount=12
harveydunn
Post by harveydunn »
Thank you, Ed, that is really helpful. The imprecision of the height adjust might be a deal-breaker for me.
greitz
way tube adjustable stop collar
Post by greitz »
from Ed's post (#28):
"Height adjustment. While the quill is great as a way of adjusting the blade location or for setting stops while drilling it is no where near the fine adjustment you would like to have when routing. Yes it works. But when you are accustom to adjusting a router this will seem like you are back in the dark ages."
I don't know how you would design one to be easily installed and removed, but an adjustable stop collar on the way tubes (to position the table carriage) might be very useful.
Gary
benush26
Post by benush26 »
greitz wrote:from Ed's post (#28):
Gary
I would imagine if you used a jig similar to what Dusty uses to micro adjust table tilt, but instead loosened and tightened the carriage lock system to raise and or lower the table, that would work.
Mike907
Post by Mike907 »
There is this rip fence - http://www.shopsmith.com/ownersite/catalog/rm_proroutertable.htm, which attaches to your 520 fence, but I am not sure if there is enough room for it in the Mark 7 router mode.
Mike907 wrote:There is this rip fence - http://www.shopsmith.com/ownersite/catalog/rm_proroutertable.htm, which attaches to your 520 fence, but I am not sure if there is enough room for it in the Mark 7 router mode.
Why not? Only 2 1/2" narrower.:confused:
Mike907
Post by Mike907 »
Make that a Router Fence. The only reason I'm not sure is that I haven't tried the setup. I'll give it a try and report back with pics when I can.
harveydunn wrote:I went yesterday. It was a complete waste of my time. The presenter was terrible, and had zero interest in answering the questions of someone who doesn't already own a ShopSmith.
This comment does not compute!! If I am not mistaken, the presenter was Mike Young and Mike is a dedicated, well informed Shopsmith sales person who loves to talk about the virtues of the Shopsmith.
The Shopsmith table is almost as large as most router tables and can be further expanded by incorporating a floating table. It seems to me that table size would not be an issue. It certainly is not "for me" in the drill press mode of a common 520 set up.
harveydunn wrote:Thank you, Ed, that is really helpful. The imprecision of the height adjust might be a deal-breaker for me.
I have no experience with this configuration but it seems as though the Adjustable Stop Collar would provide for the required "fine tuning". I use it on occasion for adjust the depth of cut in saw mode which seems as though it would be the same.
If not maybe the Mark 7 is not the right tool for this particular job. It is impossible to be all things to all situations.
I'm still just thinking about this. Just how often does one need to adjust a router for a change of just a couple thousandths.
