Headlight issues with these new plastic lens
ChrisNeilan
Re: Headlight issues with these new plastic lens
Post by ChrisNeilan »
I wet sand mine with micro mesh pads. Good as new!
Chris Neilan
ecom1
Post by ecom1 »
Part of the problem is that wet sanding and polishing removes the UV coating on the lens, so it won’t last. The only product I know of that has a replacement for the UV is a headlamp repair kit from Novus. Its not the 1-2-3 kit - its a kit specifically for headlamps.
Shopsmith: 2 Mark V 510 (1988,1993), bandsaw, jointer, mounted planer, belt sander, scroll saw, strip sander, lathe duplicator, conical disc sander, biscuit joiner, free standing router table with Jointech IPM-1
Other stuff: Bosch glide mitre, Ridgid 13" planer, Rikon drill press, routers, drills, and other toys
ecom1 wrote:Part of the problem is that wet sanding and polishing removes the UV coating on the lens, so it won’t last. The only product I know of that has a replacement for the UV is a headlamp repair kit from Novus. Its not the 1-2-3 kit - its a kit specifically for headlamps.
All of the products I looked at have a process to provide the coating. The last one I used was a spray, this one a soaked pad. Yes make sure they are for headlights and follow the instructions given. I would not attempt to use other products not designed for headlamps.
nuhobby
Post by nuhobby »
Not to rob this thread, but I just saw an interesting post on plastic-polishing, also related to Lathes... Enjoy...
https://www.instagram.com/p/BryPG7gAsUg/
Chris
