Beginner - Hobby
Re: Beginner - Hobby
Cap
In your list the only one that be eliminated for now is the lathe turning supplies that you listed first. All the others ( the bottom three )
I would consider to be necessary.
Ok thanks. That would be around 350$. I guess I can slowly add over time. The jointer itself is 489 which is included. I've watched some videos on turning bowls, that looks pretty cool. I might get that eventually.wa2crk wrote:Cap
https://norfolk.craigslist.org/tls/5333855401.html
Is this the 500 model? Table seems smaller but has everything for 250. No jointer like the other.
Yes that is a model 500. The table is smaller but it looks to be the proper length. A jointer is a good tool but since I have been buying saw blades that give a glass smooth finish I don't use the jointer much.
If you want to do lathe work buy some used tools first and learn how to sharpen them. Don't do experimental grinding on expensive tools
You may want to go the SS website and look at the history of the different Mk5 models. I think that from that site you can also get a feel for what was included when the machines were sold new. When you look at a machine ask to see everything that the seller is including in the sale. If things are missing adjust your offer accordingly.
OK, same was the wrong word but a Reevs drive is a Reevs drive. They all work on the same principle just not all constructed the same.JPG wrote:Similar design principles, yes. "The same", no way. Walnuts and coconuts.jsburger wrote:Fixing a Greenie is not much more complicated the a 10ER. The drive is the same a s the 10ER speed changer. The speed control dial is the only real difference and it is pretty simple.ERLover wrote:I wouldn't know where to start on fixing the greenie.
All is here videos, pics JPG, they are simple, check out the Maintenance site
True, but for education purposes, a jointer is also used to flatten one face of a board that may be cupped or twisted or rough sawn. The board can then be run through a planer to flatten the other face. If you intend to buy only straight, surfaced boards, then you can probably get by without a jointer.wa2crk wrote:Yes that is a model 500. The table is smaller but it looks to be the proper length. A jointer is a good tool but since I have been buying saw blades that give a glass smooth finish I don't use the jointer much.
Bruce wrote:True, but for education purposes, a jointer is also used to flatten one face of a board that may be cupped or twisted or rough sawn. The board can then be run through a planer to flatten the other face. If you intend to buy only straight, surfaced boards, then you can probably get by without a jointer.wa2crk wrote:Yes that is a model 500. The table is smaller but it looks to be the proper length. A jointer is a good tool but since I have been buying saw blades that give a glass smooth finish I don't use the jointer much.
Found this locally for a jointer.
http://norfolk.craigslist.org/tls/5282931676.html
I'll check the history out, definitely been researching.
http://www.shopsmith.com/ownersite/toolhistory.htm
Is the 500 table size that much of a difference?
Thanks wa2crk. Good idea with used lathe tools.wa2crk wrote:Yes that is a model 500. The table is smaller but it looks to be the proper length. A jointer is a good tool but since I have been buying saw blades that give a glass smooth finish I don't use the jointer much.
Yes Yes Yes.
"If you intend to buy only straight, surfaced boards" where the heck would that be. Those boards pretty much don't exist. That is why you need a jointer, planer and a table saw. I mostly use rough sawn stock and those tools are essential. The other essential tool is a band saw.
- rjent
Where are you getting rough sawn?jsburger wrote:Bruce wrote:True, but for education purposes, a jointer is also used to flatten one face of a board that may be cupped or twisted or rough sawn. The board can then be run through a planer to flatten the other face. If you intend to buy only straight, surfaced boards, then you can probably get by without a jointer.wa2crk wrote:Yes that is a model 500. The table is smaller but it looks to be the proper length. A jointer is a good tool but since I have been buying saw blades that give a glass smooth finish I don't use the jointer much.
Yes Yes Yes.
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
1951 jigsaw X 2
