Meet the newest member of my family
ERLover
Re: Meet the newest member of my family
Post by ERLover »
I am so confused :confused: So many of my quotes here, I dont know how many ER guards I have for free. Maybe 3 for sure or 2.
tomsalwasser
Post by tomsalwasser »
skou wrote:Tom, I may have some more experience with the Model 10 than most. (ER Lover may have me beat, though) Let me know what I can do to help you. I do have a set of metal legs as well as the casters not attached to a machine. You'll pay shipping, plus a dime or 4. steve
Thank you kindly for your offer to help Steve, and I will take you up on that. I would buy those legs but I think Dick has his heart set on them so I will gladly defer. I'll get a set of metal legs sooner or later but for now I have the big pink behemoth on wheels supporting my 10E lathe.
Tom
tomsalwasser
skou wrote: once removed, the drive sleeve, with all its bearings will slip back in, with NO issues. Provided the headstock is clean. You need to be able to simply assemble this tool, as well as disassemble it. I work on cars 40 hours a week. Hans didn't build a car! steve
Fantastic! Great news, thanks Steve.
tomsalwasser
ERLover wrote:I am so confused :confused: So many of my quotes here, I dont know how many ER guards I have for free. Maybe 3 for sure or 2.
Sounds great ER-dude, thank you. From what I recall you live near Appleton or thereabouts, do you not? I live in St Paul and my son lives in Plymouth (WI) so I pass very near you several times a year. Let's keep in touch!
Tom
oldiron
Post by oldiron »
skou wrote:
oldiron wrote:Tom, As JPG mentioned, The drive sleeve needs to be carefully pressed back into the headstock casting. You only need to tap on the outer bearing race to press it back in.
I also apply a very small amount of Indian Head type gasket sealer to the outside of both bearings races upon installation which will prevent any possible bearing spin inside the headstock bore.
Keep in mind, The drive sleeve bearings are basically "slip fit" back into the headstock.
Mike, once removed, the drive sleeve, with all its bearings will
When I re-assemble a headstock, the Indian, as well as his Head,
are NO WHERE around.
steve
Steve,
I have seen 10ER drive sleeve outer bearing races spin in the headstock upon start-up of the machine. As for the Indian head gasket material, I'm only talking about a narrow 1/4" strip applied to one spot on each of the outer bearing races just as a extra measure to prevent the race from spinning in the headstock and it would allow easy removal if needed.
ERLover
Post by ERLover »
@Tom>Sounds great ER-dude, thank you. From what I recall you live near Appleton or thereabouts, do you not? I live in St Paul and my son lives in Plymouth (WI) so I pass very near you several times a year. Let's keep in touch!
I am in Brookfield at moms most of the time now being her care giver, but I have one here for sure, from the last rescue. Also my dentist is in Random Lake a bit south of Plymouth, I have an appt up there on March 10th
rjent
Post by rjent »
Tom
Don't defer Tom, you have first dibs on them, and I only need the casters, I already have a set of metal legs, just need to get some casters, you need both, so go for it, I will find some (or make an equivalent setup).
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
ERLover
Post by ERLover »
I have not torn a ER apart, or a restoration, just dismantled, all of mine came running and in good shape except for some rust on the way tubes, and I redid speed changers. Actually more experience on a Greenie, I had to replace belts and some bearings on that one.
Ya house is on Stroebe Island just east of I41 and just south of county road BB, [Prospect Ave] exit, south west end of Appleton.
tomsalwasser
rjent wrote:Don't defer Tom, you have first dibs on them, and I only need the casters, I already have a set of metal legs, just need to get some casters, you need both, so go for it, I will find some (or make an equivalent setup).
OK thx Dick. Steve I've sent you a PM.
Tom
rjent
Post by rjent »
Tom
Steve never responds to my PM's anyway .... Image :D
Dick
1951 jigsaw X 2
