Right on, Ed! I aligned my Mark V right after the move from Texas. It's been that way for 14 years now.Ed in Tampa wrote: I got out my Shopsmith manual and went through basic setup and alignment. My machine is now where it should be. And I ain't checking anything unless I drop a huge 8x8 on it.
Repeatability, Accuracy or Resolution
Re: Repeatability, Accuracy or Resolution
To put into perspective the effect of a not perfectly positioned wixey used to set table angle, set the table to 45°. place the wixey on the table at a right angle to the quill axis(parallel to the miter gauge face or against rip fence)
Now rotate the wixey say 5 degrees. Visually that mis-alignment is obvious.
Now read the wixey indication.
