Only the turner knows.JPG wrote:Hmmmm! Maybe change in moisture(humidity)?
It had to be round when turned!
Orrrr, maybe sanded?
If to use those beautiful things, I am sure they would be a dribble/chin wetter.
Everett, I shaped the rim with a dremel after I finished turning it. If you look closely at the first picture you will notice the rim is not quite even, the segments between the "petals" are slightly shorter and I would have had to flatten the tops of the petals to make the rim flat, which I didn't want to do. So I came up with the idea to grind a slight curve between the petals with my dremel.everettdavis wrote:Really impressive. How did you turn the rim?
