YouTube Videos featuring Shopsmiths
RobertTaylor
Re: YouTube Videos featuring Shopsmiths
Post by RobertTaylor »
Chris Neilan has several project videos using his ShopSmith
https://www.youtube.com/channel/UC0cVfX ... EWWUgSyNPg
rpd
Post by rpd »
This video shows an older Mk V powered by a treadmill motor to achieve slow speeds for large turning.
He also has several more videos showing how he did the conversion in more detail.
[youtube]https://www.youtube.com/watch?v=Mb_OsFXf6cc[/youtube]
everettdavis
Post by everettdavis »
I have actually done that press like you show in the first thread post before, however I used the large Turning Face-plate to attach the press block.
It worked really well on our project.
Everett
ChrisNeilan
Post by ChrisNeilan »
RobertTaylor wrote:Chris Neilan has several project videos using his ShopSmith
And a few in the planning stages as well!
Chris Neilan
rpd
Post by rpd »
Part of a restoration in progress.
[youtube]https://www.youtube.com/watch?v=MSCj-VLmuYU[/youtube]
Hobbyman2
Post by Hobbyman2 »
There is a lot of videos on the shopsmith , one reason it is a good investment.
Hobbyman2
rpd
Post by rpd »
Two Philip's - Two Shopsmiths. A father and son working in the shop. Shopsmith jointer gets used near the end.
[youtube]https://www.youtube.com/watch?v=s85U1cGoDxk[/youtube]
everettdavis
Re: YouTube Videos featuring Shopsmiths -10ER Speed Control
10E /10ER Speed Control Running https://youtu.be/L3vhOK-FqVU
Tried this embed code but not working....
[youtube]https://youtu.be/L3vhOK-FqVU[/youtube]
Here's another that is interesting
https://youtu.be/-Zk51fhHq-0
Everett
everettdavis wrote:10E /10ER Speed Control Running https://youtu.be/L3vhOK-FqVU
Everett
Wonder what speed ranges are obtained with that unusual/reversed pulley arrangement? ***
Appears to be an 'early'(0-8) version.
*** the reversal comment is wrong. The use of a 5" pulley in place of the 4" pulley gives a (0-5) range of 2313 to 8500. I do not know what the extended 5to8 ratios are(assuming the earlier sliding sheave).
everettdavis
As you watch that second video, it shows him measuring it with a tach at just over 210 RPM at the quill.
Everett
