3D SketchUp of the "Under-the-Mark V" Accessory Cabinet
Asbrand
Re: 3D SketchUp of the "Under-the-Mark V" Accessory Cabinet
Post by Asbrand »
Oh, and if anyone wants to use the blade arbors I drew up, that thread is here:
http://shopsmith.com/ss_forum/community ... 19891.html
-Az
Asbrand
Post by Asbrand »
Looks like the saw blade pocket on the left side is reachable. Might need to lower it just a wee bit, but should be doable. Room on the other end for one as well.
Click here to see:
https://scontent-iad3-1.xx.fbcdn.net/v/ ... e=59523B26
-Az
Asbrand
Post by Asbrand »
Ok, guys...I've finished (I think) the new re-design. Go download it into Sketchup and see what you think?
If it passes muster, I'll do the parts layout cutsheet and re-upload it.
https://3dwarehouse.sketchup.com/model/ ... abinet-v20
-Az
t3steve
Post by t3steve »
I like it, but a question is there space in it to store the 510 table connector tubes, legs and auxiliary tables?
roopurt5
Post by roopurt5 »
t3steve wrote:I like it, but a question is there space in it to store the 510 table connector tubes, legs and auxiliary tables?
I would think you could, depending on what else you were storing in the main body of the cabinet, but I can't say for certain without dimensions of both. The tubes and legs, for sure, but I don't know about the tables.
It'll pass muster but once built you may occasionally grit your teeth. I am still skeptical about mounting and unmounting a saw blade and arbor on the ends of the cabinet.
Your cabinet measures 48 1/4". You'd be uttering unrepeatable nothings if you tried to put that cabinet between the end casings on my machine.
All that said, I like it.
Do you plan to put casters under it?
Asbrand
Post by Asbrand »
Thanks guys.
The 48-1/4" measurement is exactly what mine is. *shrug*
No plans to put casters underneath it.
And, you don't have to put a saw blade pocket on the end if ya don't want. Was just trying to make use of dead space. :)
-Az
t3steve
Post by t3steve »
I like it, I need to build a storage cabinet. As soon as I get some time, I'm on it.
Steve
cham-ed
Post by cham-ed »
Asbrand wrote:Thanks guys.
:rolleyes:
What if you rotated the blade pocket 45 degrees. Then the blade would go in at an angle making it a lot easier and give better clearance.
Asbrand
Post by Asbrand »
Model has been updated with the cutsheets, with all parts laid out, including a 1/8" kerf space between each part.
Model on SketchUp 3D Warehouse has been updated.
PIC of the layout:
-Az
