Here's the picturethunderbirdbat wrote:Picture size plays a part as well as file size to upload a picture all must be met. The picture should be 2050 x 1180 pixels with a file size of 2 MB. If the picture fails to load, look at the top of the page to see why. You may have to scroll up to see it.
Woodworking Projects I page 79 has the plans for a Toy Kitchen made from 2 sheets of 1/2" plywood or particleboard. The info states that the plan is from the Hands On Sept/Oct 82 issue. The entire entry is only one page.
Looking for some plans
dannyshamoon
Re: Looking for some plans
- stove2.jpg (148.27 KiB) Viewed 10904 times
- thunderbirdbat
Not sure what you are looking at but pg 13 of Woodworking Projects I is part of a gumball machine.beeg wrote:thunderbirdbat wrote:The info states that the plan is from the Hands On Sept/Oct 82 issue. The entire entry is only one page.
Also it's on page 13.
The Toy Kitchen is not the same. PM sent.
Brenda
1998 bandsaw
2016 beltsander
jointer
overarm pin router
1998 bandsaw
2016 beltsander
jointer
overarm pin router
"The info states that the plan is from the Hands On Sept/Oct 82 issue. The entire entry is only one page."
If you use Sketchup it shouldn't take very long to knock out a set of plans for something like this. Sketchup is free to download and both Zeh and Lange have video instructions for how to use it.
It appears to be a set of basic boxes which is a quick build. The real benefit of Sketchup is that you can view it from any angle to see if the proportions look right before you start making sawdust. I design all my jigs on Sketchup before I build them.
dannyshamoon
I've tried Sketchup before and found it hard to use. Mostly because I can't do a straight line, which makes my woodworking hard toomarcs4095 wrote:If you use Sketchup it shouldn't take very long to knock out a set of plans for something like this. Sketchup is free to download and both Zeh and Lange have video instructions for how to use it.
I'll give it another try and see if I can figure out the dimensions.
Thanks
Danny
I bought an Oct 1955 Mark 5 parts machine yesterday. In the materials with it was a small pile of Hands ON. Here's the Toy Kitchen.
It is not the exact one you were looking for but I hope it helps.
