Is the 520 Pro Fence and Table System Upgrade worth it?
Re: Is the 520 Pro Fence and Table System Upgrade worth it?
Damn I am glad we all finally got on the same side of the table!
I am coming in late on this one but I definitely like the 520 fence. More t slots for stock guides etc and aligns better than the 500 of 510. I started with the 500 fence and thought the 510 was great but the 520 is a major upgrade IMHO.
Paul
Paul
ONLY if someone leaves the room!
Whodat???dusty wrote:ONLY if someone leaves the room!
As the originator of this thread, I truly appreciate everyone's input. I have learned a lot.
It's a time in this country where nothing is unanimous, but, thanks to all you guys, I received a definitive and unanimous answer - the 520 fence upgrade is worth it.
Ok, I'll save up my lunch money and watch for the 520 Pro Fence Upgrade to go on sale.
Thanks again.
Runamuk13
Thanks again.
Runamuk13
Mark V - 500 --> 510 --> 520 --> 7 PowerPro
Bandsaw, Jointer, Planer and more
Shopsmith owner since 1984
Here's a used upgrade for about $185 less than new from Shopsmith, plus seller accepts returnsrunamuk13 wrote:Ok, I'll save up my lunch money and watch for the 520 Pro Fence Upgrade to go on sale.
https://www.ebay.com/itm/Shopsmith-Mark ... SwwmBci8eG
Don't hold your breathe!runamuk13 wrote:As the originator of this thread, I truly appreciate everyone's input. I have learned a lot.
Thanks again.
Runamuk13
I haven’t a solution, but I did explore one using neodymium magnets. K&J magnetics sell N42 as thin as 1/32”. They have a couple rectangular magnets, B3301 is 3/16 x 3/16 x 1/32 and B6301 is 3/8 x 3/16 x 1/32. I had though of scraping off the magnet on the table and epoxying a few magnets along the way. Maybe put in 1/32 shims in between the magnets to give the tape a level and stable base. I’ve knocked off the plastic guide so many times that I made a replacement using some thin aluminum bar stock bent to an ‘L’ and attached using sliding T-nuts. Maybe this spring or Summer I’ll try the magnet replacements. Currently the B3301 are 14 cents each quantity 1 (they offer discounts but I think you need to buy 10 before it goes into effect) and the B6301 are 23 cents each.RFGuy wrote: I wish my stainless steel tape measure was just slight narrower in width so that I couldn't accidentally catch the edge of it and lift it like this, or I wish the magnet could be a rare earth magnet kind that has more holding force. I haven't seen any adhesive backed rare earth magnet tape though. Anyone else have this problem with the 520, or better yet anyone have any fixes or tips they can share? This problem doesn't happen often to me, but when it does it is annoying
Hope that gives you another thought path.
Be well,
Ben
Yes I have had issues with the rules to the point that I have had to replace them after catching and actually bending them. I guess the size was so that you had a place to grip them to lift them to take them off or to reposition them. If they stick too well you might end up bending them trying to move them????RFGuy wrote:The only negative thing I will say about my 520 fence system is having to do with the stainless steel tape measure with magnetic attachment. On mine, the stainless steel tape measure is a tiny bit wider than the rail ledge on the 520 table system. What this means is that on occasion I will bump it with my hand and it lifts up throwing off the alignment that I had with the tape measure relative to the saw blade position. I wish my stainless steel tape measure was just slight narrower in width so that I couldn't accidentally catch the edge of it and lift it like this, or I wish the magnet could be a rare earth magnet kind that has more holding force.
Anyway I have no solution but I have since stopped using them for the most part. They are OK for birdhouses and the like but not close enough for more precision work, well the rules and my eye sight are finding that anyway.
On my other 520 that is set up with the saw train I never bothered to install them and ending up bending one of them to, still in the bag.....
I haven't looked around for other options but I do know that my foot long ss rule is about the same width and magnetic so I sometimes stick that on and use it. That works pretty well.
Thanks, Ben. I like your idea, but I am not sure if it will give enough improvement. For a test this morning, I went out in the shop and tried putting the stainless steel tape measure on top of some round button rare earth magnets that I had in the shop. These are 1/2" round button magnets. I was surprised how easily I could lift the edge of the tape measure off the magnet. Once an edge starts to lift it is very easy to pull the tape measure right off. It seemed like the force to hold was maybe 10% stronger with these rare earth button magnets. I know, not a scientific experiment, just my gut feel but I would have expected a lot more holding power from such a strong magnet. Thinking about this a bit more, I think the answer lies in the fact that the tape measure is a stainless steel. Depending on which type of stainless steel Shopsmith picked, the magnetic force could be quite weak due to the higher nickel content of the stainless steel.benush26 wrote:I haven’t a solution, but I did explore one using neodymium magnets. K&J magnetics sell N42 as thin as 1/32”. They have a couple rectangular magnets, B3301 is 3/16 x 3/16 x 1/32 and B6301 is 3/8 x 3/16 x 1/32. I had though of scraping off the magnet on the table and epoxying a few magnets along the way. Maybe put in 1/32 shims in between the magnets to give the tape a level and stable base. I’ve knocked off the plastic guide so many times that I made a replacement using some thin aluminum bar stock bent to an ‘L’ and attached using sliding T-nuts. Maybe this spring or Summer I’ll try the magnet replacements. Currently the B3301 are 14 cents each quantity 1 (they offer discounts but I think you need to buy 10 before it goes into effect) and the B6301 are 23 cents each.RFGuy wrote: I wish my stainless steel tape measure was just slight narrower in width so that I couldn't accidentally catch the edge of it and lift it like this, or I wish the magnet could be a rare earth magnet kind that has more holding force. I haven't seen any adhesive backed rare earth magnet tape though. Anyone else have this problem with the 520, or better yet anyone have any fixes or tips they can share? This problem doesn't happen often to me, but when it does it is annoying
Be well,
Ben
