Restoration Project
Re: Restoration Project
If "it" is your location to be seen on the forum - the answer is no. In the profile settings there are options to allow/prevent certain data from being seen out here.
When it is setup to be seen, you will see it in the upper right hand corner of your screen.
br549
Post by br549 »
If you use the shopsmith board preference like I do, then there are TWO fields labeled "Location". I learned before that anything entered in the first field doesn't show up when you post a message. If you enter your location in the second field labeled "Location", it should show up. You may need to scroll down to see it. It took 3 screen shots to capture the entire page for editing your profile.
shopsmith usercontrol panel screen 1.jpg (71.28 KiB) Viewed 12452 times
shopsmith usercontrol panel screen 2.jpg (56.91 KiB) Viewed 12452 times
shopsmith usercontrol panel screen 3.jpg (58.08 KiB) Viewed 12452 times
If you use the prosilver board preference, then the number of fields is much smaller, and I only see one field labeled "Location".
prosilver user control panel.jpg (98.67 KiB) Viewed 12452 times
Spooner
Post by Spooner »
how bout now...
You got it!! :)
Spooner wrote:I added it... did it not show up?
YES including in ALL previous posts.
BTW Minnesota is kinda big. :rolleyes:
Spooner
Post by Spooner »
Okay JPG how bout now?
Be careful. Don't put too much info out there for public viewing/abusing. I show my home town and that might be too much.
Spooner
Post by Spooner »
dusty wrote:Be careful. Don't put too much info out there for public viewing/abusing. I show my home town and that might be too much.
I'll be careful Dusty. Thanks for the heads up... :)
I think a town is safe enough! ;)
Spooner
Post by Spooner »
I'm convinced you guys want my kidneys or something.
