Rusty 610 Jigsaw
tucsonguy
Re: Rusty 610 Jigsaw
Post by tucsonguy »
Did anyone ever install an aquarium check valve and test it out? Seems like an easy, cheap solution; the question is how much of a reduction in air fllow it might cause.
Guess I'll be the guinea pig here.
I also noticed this morning that after reassembly of the two pieces of the check valve puffer assembly that the two pieces are looser than they were, I can twist the top part slightly. Guess this means I need to replace the gasket with slightly thicker material.I could just silicone it together but that would make future disassembly more difficult.
Geoff Baker
1951 10ER w variable speed electronic motor with reverse
1999 520 w PowerPro
Belt sander - strip sander - bandsaw - scrollsaw - jointer - overarm router - undertable router mounted on main SS saw table - speed increaser - speed reducer - forced air HEPA filter for headstock - 19" SS powered aluminum drum sander - index wheel system - lathe table crossslide vise system
Geoff,
If you are going to replace the gasket you will have to make it yourself. Keep in mind that the Jig Saw was discontinued years ago in favor of the Scroll Saw and new replacement/repair parts from Shopsmith are no longer available. The only other option to a gasket replacement is finding a used part which may have the same problem.
I have used aquarium airline as a replacement on the Jig Saw. I am curious to know if an aquarium check valve would work.
"I have used aquarium airline as a replacement on the Jig Saw. I am curious to know if an aquarium check valve would work."
If placed in the correct location it should. The tubing going to the 'nozzle' should be a good location.
