What goes on in your shop?
ronhollenbeck
Hands On Grandfather Clock Plans
Post by ronhollenbeck »
Has anyone else built the grandfather clock from the Hands On plans? I've built two from walnut. The first was an anniversary present for my parents and the second is in my livingroom. The Hands On plans can be found at http://www.shopsmithhandson.com/archives/sept_oct_00/index.htm
This is the best looking plans built clock I have been able to find. I hope more people try it.
I mostly build furniture for myself or family members. I'm currnetly doing an entertainment center for a wide screen flat panel tv and stereo equipment. I'll do a post on it later.
ronhollenbeck
"Hands On" Grandfather Clock
sawmill
Post by sawmill »
This past summer I bought a Shopsmith with a bandsaw for 40.00 at a sale. Since then I rebuilt the head and put it to work making toys for the grandkids. I have some furniture to build and then I am moving to our other home. After the move I will be building a new workshop by using the lumber sawed off this land. I plan on having a hard maple floor that will be 1 1/2 inches thick with in floor heat. I will saw all the lumber using my saw mill and when the shop is done the shopsmith will go to work making cabinets and what ever else I need to finish it off.
Greenvilleguy
Post by Greenvilleguy »
Ron,
The Grandfather clock is beautiful. The "crotch" veneer in the lower door is really stunning!
mlwiltse
My shop projects
Post by mlwiltse »
I mostly make harps in my shop. I play harp and teach so my harps go to students, sale and rent. I've done some other small instruments and am getting set up to try making a few Native American Style Flutes. Although I haven't used the shopsmith for anything but a drill press for years (and a place to stack things on)...I'm going to see if I can get it going to use it as a lathe. I took a turning class at Woodcraft last weekend....what fun! Melanie
http://www.harpsongstudio.com
I'll attach a photo of my most recent harp if I can figure out how to do it. It's number 40. (I've been making harps for about 6 years.)
rolands
Post by rolands »
Ron and Melanie, you both do excellant work. Your projects look great.
ericolson
Post by ericolson »
Ron and Melanie;
I have to second what rolands said: beautiful work!
Melanie, if your lathe work turns out as nice as your harps, then it should be goargeous!
Eric
Rock Creek Designs
Win if you can, lose if you must, but always cheat!
woodshaper
Post by woodshaper »
Ive owned my 10e for about 20 years and have used every function on it from making pens ,coffee tables, wind chimes,bird feeders, bird houses, I also do yard art, scrollsaw work,and stain glass that I incorporate into some of my wood work. If its wood Ill make.
woodshaper
what goes on in your shop
woodshaper
I do alot of pen turnings, and small turnings, thinking of doing some bigger stuff like vases and lamps, I also do yard art, bird houses and feeders,coffee tables,book cases, alot of whimsical stuff like wind chimes, whirlagigs,old timey looking latterns made from wood and masson jars. If its wood I enjoy making it.
