Noisy Jointer
garyshell
Re: Noisy Jointer
Post by garyshell »
So would the loctite not be sufficient?
Re: Noisy Jointer
I have never had a pulley set screw come loose and I don't understand why it is but hopefully the Loctite will work. bill50cal and JPG were offering other options. If I was having that problem, I think I would try the nylock set screw option first. Not to say Loctite is not a good option just that a nylock set screw would simply be my preference.
rpd
Re: Noisy Jointer
Post by rpd »
Regarding the link belt clearance. You could rotate the eccentric tubes 180 deg. so that the offset is towards the opening instead of away from it. That would move the pulley to where the legs on the mounting base are further apart and give you more clearance.
garyshell
Re: Noisy Jointer
Post by garyshell »
rpd wrote: Mon Dec 20, 2021 2:14 am Regarding the link belt clearance. You could rotate the eccentric tubes 180 deg. so that the offset is towards the opening instead of away from it. That would move the pulley to where the legs on the mounting base are further apart and give you more clearance.
I will take a look at this tonight.
Thanks.
