Time to restore the 510
- mickyd
[quote="cat_couple"]Well to update all]
Can't wait to see the machine Eric.
The bearing should be replaced. A greased bearing will not spin freely. You could try repacking it. Member robinson says get it hot by leaving it on a light bulb then drop it into bearing grease and let it cool. While it cools, it will draws the grease in. Never tried it. I'd go for new personally since they are so cheap.
Sunny San Diego
Sunny San Diego
cat_couple
- cincinnati
Thanks for posting your progress.
Noticed you are from New Philadelphia, Ohio. I make my way up to Sugercreek once or twice a year. Like going through the antique mall called Rivers edge or something like that. Also how lucky are you to live so close to Keim Lumber and Hartville Hardware.
cat_couple
cat_couple
Here are some pictures of the parts as I am painting and wire brushing
- 100_0914.jpg (174.03 KiB) Viewed 5050 times
- 100_0916.jpg (175.67 KiB) Viewed 5050 times
- 100_0917.jpg (176.86 KiB) Viewed 5045 times
- 100_0918.jpg (180.97 KiB) Viewed 5048 times
Eric J. Hovan
1988 Model 510 S/N 555188, 10 ER S/N# 41855, bandsaw, jointer, belt sander, scroll saw.
cat_couple
Still more photos
- 100_0919.jpg (240.62 KiB) Viewed 5049 times
- 100_0920.jpg (243.13 KiB) Viewed 5044 times
- 100_0921.jpg (285.76 KiB) Viewed 5049 times
- 100_0922.jpg (231.82 KiB) Viewed 5051 times
Eric J. Hovan
cat_couple
I like the black and silver idea. I can't wait to see it put together.
Heath
Central Louisiana
Central Louisiana
Beautiful work! Especially the ShopSmith red dial and cover. The speed dial would really shine with red infill of the lettering or is it already black?(Can't tell from the pix).
