Misaligned arm locking pin
fredsheldon
Post by fredsheldon »
Install the lift assist and the problem will go away forever.
Fred Sheldon
The Woodlands, Tx
zachnoll
Re: Misaligned arm locking pin
Post by zachnoll »
So mine is fine? I thought it looks way off. I took the machine off when I took this picture so maybe the weight also helps set it. Am I wrong?
edma194
Post by edma194 »
zachnoll wrote: Thu Mar 06, 2025 3:49 pm So mine is fine? I thought it looks way off. I took the machine off when I took this picture so maybe the weight also helps set it. Am I wrong?
Yours looks fine. The pin isn't supposed to line up centered with conical hole.
Matanuska
Post by Matanuska »
I recently discovered that if I rock the vertical drill press slightly as I tighten the knob it will lock in very securely, sometimes so securely that I have to use channel locks to undo it after I've finished drilling.
- Matanuska
1984 Mark V upgraded to 520 PowerPro. Shopsmith cast iron table bandsaw, jointer, belt sander, and 60's vintage 610 jigsaw SPT's. Makita 2040 15" planer, JessEm Mast-R-Lift II router table.
That "misalignment" is a common concern. However it is supposed to be that way. The tapered screw and the slope of the huge dimple create an over the center locking. The screw must be backed out substantially before the locking is released.
It is not necessary to use gorilla tactics when tightening the screw, but it can/will shift the casting away from the screw. That 'slop' must be taken up.
Matanuska
Post by Matanuska »
No gorilla force used when tightening - just a slight forrward rock of the vertical drill press combined with a gentle finger tightening of the locking pin allows the pin to seat more deeply. When the press rocks back its weight locks the pin firmly in place. Releasing the pin requires the same slight forward rock. After doing this and using the drill press for awhile I’ve noticed that it sometimes seems to tighten even further on its own requiring considerable force to unlock even when combined with the forward rock. Not recommending, just an interesting obersvation.
- Matanuska
