Power Pro Case
mickyd wrote:Gotta destroy 'em to QC 'em. Only do destruct tests on aerospace and militiary spec fasteners.
Got an opening for an old Environmental and Nuclear Survivability Test Engineer?
horologist
Post by horologist »
mickyd wrote:What's Ftu / Fsu? Haven't dealt with that in my QC world.
Sorry Mike, I should have been clearer.
Ftu = Ultimate tensile stress
Fsu = Ultimate shear stress
Most of our standard steel or titanium bolts have a minimum Ftu of 160 ksi (160,000psi) and an Fsu of 95ksi.
Troy
robinson46176
Post by robinson46176 »
With all of the engineering going on here you guys missed the obvious "strip of duct tape slapped across it" cure... :D
Also in my history are incidents of covering a gap with a nice piece of chrome trim. :) or maybe a nice strip of walnut.
Actually, the return to SS is the best answer since curing it will tell them exactly what they need to do to permanently eliminate the problem in assembly. "Someone could get the chop"... :eek:
horologist
robinson46176 wrote:With all of the engineering going on here you guys missed the obvious "strip of duct tape slapped across it" cure... :D
What's that expression? Can't see the forest for the trees...
Although a chainsaw and a woodmizer will soon have that problem settled. :D
Troy
horologist wrote:What's that expression? Can't see the forest for the trees...
Troy
I like that!!!!!!!
mickyd
Post by mickyd »
horologist wrote:Sorry Mike, I should have been clearer.
Troy
Troy,
In 'my' fastener world, the stress vs. strain curve (load vs. deformation) yields UTS (ultimate tensile strength) and UYS (ultimate yield strength). The alloy cap screws aren't spec'd out shear strength like a dowel or roll pin is unless your considering max rotational torque shear. UTS on an alloy socket cap screw is 180,000 psi minimum and UYS is 162,000 psi minimum.
Wonder what your Ftu / Fsu acronym stands for??:confused:
Sunny San Diego
horologist
mickyd wrote:Troy,
Mike,
Sounds like we are on the same page, indeed you may manufacture some of the fasteners we use at work. But are these values for the cap screws found in the typical hardware store? Not that it makes a bit of difference in this case, even the lowest grade Chinese screw will have ample margin.
F is a symbol commonly used to denote stress, the subscript t is for tension and u is for ultimate and so on.
Troy
mickyd
Post by mickyd »
horologist wrote:Mike,
Troy
Troy,
Inch alloy steel socket cap screws are required by US law to meet the same specification requirements. If they don't, they cannot legally be called a socket cap screw.
Metric alloy socket cap screws however can come in 3 different minimum spec ranges for strength. All metric cap screws are required by US law to have specific head markings in order to differentiate the three. The metric head marking '12.9' approximates the strength of the inch socket cap screws.
FYI - The US Borders and Customs Agency is responsible for overseeing all fasteners imported into the country to ensure that they comply with US mandated specifications.
Sunny San Diego
Stitch
Post by Stitch »
There has certainly been a lot of discussion for a "cosmetic" problem. Has anyone asked if it is possible that the holes are in the wrong location. Were these holes drilled as part of the DIY upgrade.
mickyd
Post by mickyd »
Stitch wrote:There has certainly been a lot of discussion for a "cosmetic" problem. Has anyone asked if it is possible that the holes are in the wrong location. Were these holes drilled as part of the DIY upgrade.
jctorick already sent it back to ShopSmith but to me, it would be very doubtful that the condition could be from holes not lining up. I've had times when holes didn't line up by just a smidgen and it was a bear to get the screw started. It would take a gorilla to buckle the sheet metal that much IMHO. The PowerPro unit was new.
Sunny San Diego
