Shed install
john
Post by john »
I used deck blocks as the supports for my ground level deck about five years ago. The deck is about 12 x 14 feet. So far there has been no movement even though we get pretty cold and snowy winters.
I would imagine the deck blocks would work as well for a small shed. Just be sure to add a wire skirt around it or the groundhogs, skunks and other critters will find their way under it.:D
Good luck
John
robinson46176
Post by robinson46176 »
wannabewoodworker wrote:Fender washers and nyloc nuts. Only problem is these hardware pieces always use such small hardware to mount them. I had to use 10/24 screws and nuts as anything larger would not have worked out.
When I mount a hasp I usually drill a square hole in the center of the mount part of the hasp and use a carriage bolt through it...
wannabewoodworker
Post by wannabewoodworker »
robinson46176 wrote:When I mount a hasp I usually drill a square hole in the center of the mount part of the hasp and use a carriage bolt through it...
Unfortunately that would not have worked on this particular lock/hasp device. I got this one because it has a locking latch that fits through the hasp and turns. It looks much nicer than having a big ugly hasp with loop and huge padlock on it. Had to keep the wifey happy too you know.............:D
Michael Mayo
Senior IT Support Engineer
Soft Designs Inc.
albiemanmike@gmail.com
1960's SS Mark VII, 1954 Greenie, 1983 Mark V, Jointer, Bandsaw, Jigsaw, Dewalt Slider, Delta Super 10, Delta 8" Grinder, Craftsman compressor, Drill Doctor, Kreg PH Jig, Bosch Jigsaw, Craftsman Router and Table...........and adding more all the time....:D
I know how to 'drill' square holes in wood(mortise bit) but what kind of bit drills a square hole in steel? A bastard bit(handle optional)?:D
robinson46176
JPG40504 wrote:I know how to 'drill' square holes in wood(mortise bit) but what kind of bit drills a square hole in steel? A bastard bit(handle optional)?:D
A square bit of course... ;)
Actually I usually just drill a regular hole and then square it out with a tapered square punch at the anvil in the blacksmith shop using the pritchel hole. On thin stuff cold is fine. On thick iron a little red glow helps a lot.
robinson46176 wrote:A square bit of course... ]pritchel hole.[/B] On thin stuff cold is fine. On thick iron a little red glow helps a lot.
Not being farriers, you just gotta explain that one to us! :confused:
robinson46176
JPG40504 wrote:Not being farriers, you just gotta explain that one to us! :confused:
Here is a "pritchel hole".
[ATTACH]13233[/ATTACH]
This page which appears to be a good one on nail making has a brief discussion of a square punch / drift.
Scroll down about 3/4 of the page.
http://www.piehtoolco.com/Product_Info/nailheading.htm
wannabewoodworker
This will be my last post on the shed. I just wanted to post a completed shed build pic for those of you that have helped me out with the saga of my first structure building project. I am pretty pleased with the outcome and learned a ton while building it.
Michael Mayo
Soft Designs Inc.
wannabewoodworker wrote:This will be my last post on the shed. I just wanted to post a completed shed build pic for those of you that have helped me out with the saga of my first structure building project. I am pretty pleased with the outcome and learned a ton while building it.
Nice! The local varmits will love it!;)
peterm
Post by peterm »
Very nice job on your shed. Two questions.........what was the vent for low on the right end and what is the thing on the siding below the window for?
Peter
