SS bug strikes a 3rd time
pennview
Post by pennview »
I think you want to run the black (hot) wire through the two leads on the replacement switch, connecting the whites together with a wire nut. And, don't forget the green or ground wire to the chassis.
Art in Western Pennsylvania
pennview wrote:I think you want to run the black (hot) wire through the two leads on the replacement switch, connecting the whites together with a wire nut. And, don't forget the green or ground wire to the chassis.
That be correct(switch the hot black wires).
A 20A switch is an improvement over the original, and it be the turn off that will test the switch. Next time get a double pole switch!;)
wa2crk
Post by wa2crk »
Double pole single throw switch from http://www.willyselectronics.com item #30-345
.250 quick disconnect tabs. Relatively low cost and I got them in about 5 days.
wa2crk wrote:Double pole single throw switch from www.willyselectronics.com item #30-345
This one.
http://shop.willyselectronics.com/browse.cfm/-bat-handle-toggle-on-off-dpst-20a-125v-.250-quick-connect-/4,2915.html
billmayo
Power Switch
Post by billmayo »
wa2crk wrote:Double pole single throw switch from http://www.willyselectronics.com item #30-345
I have been using this switch for years as I understand (discussions with seller) that the switching contact points are larger/heavier to handle the arcing when switching ON or OFF for this 7300001 - DPST On-Off Toggle Switch - .250 flat terminals switch.
http://www.delcity.net/store/Heavy!duty ... 789066.a_1
fiatben
Thanks for the input
Post by fiatben »
You guys are great! I appreciate the info. I'd have taken more time and started here, but I was putting this thing back together Wednesday and the switch failed during that. Since my son-in-law is coming tomorrow to pick it up, I found myself in a time crunch, and thus the trip to the big box store.
Anywho.... white to white, black thru the switch and send this thing home. It's not the full restore that I would like to have done, but he needs a drill press and repainting it will become his project.
Thanks again.
wa2crk
Post by wa2crk »
Yup--- that be it.
Bill
billmayo wrote:I have been using this switch for years as I understand (discussions with seller) that the switching contact points are larger/heavier to handle the arcing when switching ON or OFF for this 7300001 - DPST On-Off Toggle Switch - .250 flat terminals switch.
http://www.delcity.net/store/Heavy!duty-Motor!rated-Toggles/p_789066.a_1
Like thisun?]http://www.delcity.net/cartviewitem?ite ... ch=7300001[/URL]
IIRC, I have seen that number on a Gardner-Bender switch I purchased at Ace.
Ron309753
Post by Ron309753 »
A few years back I got a Gardner-Bender DPST 20A 125VAC switch at Sears for my greenie. Don't know if they still have them. It's probably the same one that Ace has.
Sincerely,
Ron309753
