So what did you use today?
swampgator
Post by swampgator »
Top of the line work there, Bud. Truly a showcase.
Steve, the old Florida gator
I just love it when she says I can go make sawdust. ;) :D
Agreed!
Did you make it in sections, or do I see layout lines?
bffulgham
Post by bffulgham »
Thanks, guys.
It is 5 separate components:
[INDENT]Base or plinth
3 stackable boxes for shelves
Top assembly
[/INDENT]
The basic plan came from Pop Wood. I modified the plan to suite what I wanted.....did half-blind dovetails to put the boxes together, solid slats for the backs instead of plywood, and mortise and tenons for the doors.
I had posted a bit on this project in the SS Elvesthread started by mrhart.
It's been a fun project....and another learning project for me. The best part if it is SWMBO is very pleased with it :D
Bud F.
STB
Emergency Repair
Post by STB »
The adventure started Friday. I left the table out over night and the wind caught it.
[ATTACH]16185[/ATTACH]
So I went to a few garage sales and found a hardboard door (with water stains) and some pine boards and 2x4s for $5.00. After removing the hardware from the broken table I cut the 2x4s with the SS and found the cordless drill (had a hard time remembering how it worked). Drilled some 1 1/8 holes in 6in blocks.
[ATTACH]16189[/ATTACH]
Cleaned up the holes with the SS.
[ATTACH]16190[/ATTACH]
A little glue some JPW in the holes a few clamps some screws for good measure. I even know what I will tell SWMBO when she notices the new table top. It will be something like "How do you like the improved table?".
[ATTACH]16191[/ATTACH]
ss projects 001 (800x563).jpg (336.98 KiB) Viewed 2135 times
ss projects 002 (800x591).jpg (444.61 KiB) Viewed 2135 times
ss projects 003 (800x600).jpg (382.18 KiB) Viewed 2134 times
ss projects 006 (800x574).jpg (398.66 KiB) Viewed 2132 times
What do you use this solution on when working wood?:rolleyes:
[ATTACH]16192[/ATTACH]:D
mystery solution.jpg (392.72 KiB) Viewed 2132 times
heathicus
Post by heathicus »
I spent most of the day in the shop and all I used was a drill and a circular saw.
Heath
Central Louisiana
STB
Post by STB »
JPG40504 wrote:What do you use this solution on when working wood?:rolleyes:
That is Desert Diamond Agave Rum Notice the easy pull cork. no wasted time unscrewing the top. I keep it in the shop at all times to prevent snake bite and it workers. In 50 some odd years that I have kept it handy. I have never been bitten by a snake.
stumpbuster wrote:That is Desert Diamond Agave Rum Notice the easy pull cork. no wasted time unscrewing the top. I keep it in the shop at all times to prevent snake bite and it workers. In 50 some odd years that I have kept it handy. I have never been bitten by a snake.
I do not see anything about snake bites!:D
[ATTACH]16200[/ATTACH]
Interesting!
d3 agave rum.jpg (163.16 KiB) Viewed 2110 times
mrhart
Post by mrhart »
This could be a another thread by itself...."what do you keep in the shop for snakes and such?"
R Hart
