dusty wrote:Do the reverse and forward keys connect to relays that actually do the power switching OR is the power switching accomplished by the switches.
I really wonder why this feature was abandoned in the transition to the early Mark 5? I never read about owners having power switching problems which leads me to conclude that it was not a reliability/dependability issue.
Now, think about it. If they had carried that reversibility feature through, half of the PowerPro's thunder would be lost.
It also seems curious to me that of the three motor manufacturers, Emerson's is the only one that is not reversible. They had to design in the non-reversible feature.
I have said before that they started back up again with the wrong one... Then again we have no idea of a possible half zillion other factors. Cost was probably the killer. I'm sure that a lot was the pent up demand for parts for all of those orphaned Mark V's and the nostalgia connected to them as well as the stigma of the 2 Mark VII minor problem spots. I say minor because if you could just order a new plastic cam for $4 or $5 melting one wouldn't amount to a hill of beans.
I'll see if I can get a picture of the backside of the switch. You can see in the picture a clear spot in the 2 outside buttons. Inside of the case behind the switch there are 2 tiny light bulbs mounted that makes which ever of the 2 buttons is pushed in glow. They do not work on mine and I do not really care.
They really did intend for the Mark VII to be a "super" Shopsmith...
On an added note, IIRC the Mark VII only uses 5' of floor space instead of 6'.
