Chad
Your DAD bought HIS Shopsmith woodworking tools from Mike Young! Let's chat with Mike!
Post by Chad »
Watch it here: https://youtu.be/3BfkdOpuk6E
While Mike Young's Youtube channel is new, videos of him demonstrating and using Shopsmith tools have been on Youtube since its inception! Mike has been demoing and selling for Shopsmith for over 35 years and has even contributed to the design of a short-lived but popular tool; the Crafter's Station. Join me as we reminisce about woodworking, woodworkers and learn what's next for Mike.
thedovetailjoint
Perfect Edges using the Unique Shopsmith Conical Sanding Disc!
Post by thedovetailjoint »
A short time ago Youtuber Mike Farrington made a bit of a splash with the introduction of his double-sided conical sanding disc. You can see it here: https://youtu.be/b-kXTKVVTL4
My issue with it and other sanding discs that mount on a traditional table saw is the fact that they are spinning at table saw speed, which is somewhere around 4000 RPM. That's super-fast for an abrasive, and can lead to burning and quickly damaged abrasives; but what's a woodworker to do? It turns out that Shopsmith beat this conical disc to market by roughly 55 years when they introduced their original conical sanding disc. In this video, we'll dig into a little bit of history and put the current Shopsmith conical sanding disc to the test on some gnarly wood edges.
Watch it here: https://youtu.be/e1Fk1_zTJ_k
conical disc thumb final.001.jpeg (327 KiB) Viewed 5702 times
http://www.Youtube.com/user/MyGrowthRings
http://Shopsmith-Tool-Hunter.Blogspot.com
thedovetailjoint
Re: My Growth Rings with Scott Markwood
Why is that pic so big?!?!
Chad
Post by Chad »
thedovetailjoint wrote: Mon Nov 15, 2021 10:59 pm Why is that pic so big?!?!
That's because you don't know the secret.
Chad Nevels
    1963 Shopsmith Mark V "Goldie" 1-1/8 hp Serial # 379185
    1980 Shopsmith Mark V 500
    1994 Shopsmith Mark V 510
    1994 OKUMA LB15 II OSP7000
    2017 OKUMA LB3000 EXII SPACE TURN MY OSP P300LA
Chad
STUMPED? Q&A: Perfect Edges using a Unique Conical Sanding Disc!
Post by Chad »
Watch it here: https://youtu.be/qpkPTMbOW8c
This video is our weekly follow-up Q&A to the weekend video, which in this case was on using a conical sanding disc on wood edges. If you missed that vid, catch it here: https://youtu.be/e1Fk1_zTJ_k And I really misread Spike's comment at 19:22! Stupid dyslexia.
🔴 Please note that this video will remain visible for ONE WEEK, and at which point it will become Member-Only. Please consider joining the 100+ other channel members in supporting the channel and get access to perks: https://www.youtube.com/channel/UCGsm...
Chad
DIY Sandpaper Discs for the Shopsmith Conical Sander & Replacing Worn Sandpaper
Post by Chad »
Watch it here: https://youtu.be/KAuJQSs1U8E
As promised here's how I change abrasive discs on the Shopsmith conical sanding disc and how to modify stock abrasive discs to work on your Shopsmith conical disc. I purchased this disc used on eBay and the paper was old and crusty and just didn't want to let go, so heat and solvents were needed. If you swap the abrasives before the adhesive gets old and cured you'll stand a much better chance of a clean removal. There's bound to be a prayer that helps, too.
Chad
Sharpening Jointer & Planer Knives on the Shopsmith Conical Sanding Disc
Post by Chad »
Watch it here: https://youtu.be/gqegXQGNeqE
Last weekend we introduced the versatile Shopsmith conical disc sander and discussed how it can be used on wood. In this video, we'll talk about how to use it to sharpen Shopsmith 4" Jointer knives and Shopsmith 12" Planer blades.
🎬 In case you missed it, here's the video on using the Shopsmith conical sanding disc for super-smooth wood edges: https://youtu.be/e1Fk1_zTJ_k
🎬 Also, here's the video on how to modify stock abrasive discs for use on the Shopsmith conical sanding disc might come in handy: https://youtu.be/KAuJQSs1U8E
mountainbreeze
Post by mountainbreeze »
Great video on the use of the sharpening jig. Did I miss it? What grit sandpaper is installed on the sanding disk?
thedovetailjoint
mountainbreeze wrote: Mon Nov 22, 2021 9:39 am Great video on the use of the sharpening jig. Did I miss it? What grit sandpaper is installed on the sanding disk?
Thanks. Yes, I filmed this as one long video and decided to break it into two; one covering the abrasives and the other the use of the jig. In doing so I guess I left that info out. If the knives don’t need reshaping I sharpen them with P220 grit Aluminum Oxide. If they have deep nicks or if I am changing the bevel angle I use P150. 150 is the grit Shopsmith recommends, but I suspect that has more to do with it being the finest grit they offer. Scott
DLB
Post by DLB »
Scott - Very informative. With no SS Planer I'm not sure I can rationalize the cost, but this jig is nice. At the beginning you referred to a video on installing/removing jointer knives and said you'd link it. I don't see that link. I know I can find it but you might want to add that where you intended it.(?)
It seems to me that the removable piece that holds the knives down could have been designed so that one side works for SS tapered blades and the other side for the more common un-tapered blades. Never having used the jig, perhaps I'm missing something.(?)
