mowarren wrote:here's the latest mailbox project from reused lumber.
Nice job! I can't help but notice:
- Your 2 bottom boards are resawn from the same source board.
- Your crosscuts are nice and clean.
- You did a nice beveled rip cut on the top pieces.
nuhobby wrote:Nice job! I can't help but notice:
- Your crosscuts are nice and clean. - You did a nice beveled rip cut on the top pieces.
Sides Also!:)
- Your 2 bottom boards are resawn from the same source board. And booked!
Sides Also!:)
yes its all resawn from used 2x6 and 2x4 and all done with the greenie I cleaned up this spring.The finish is spar urethane with uv protection so hopefully it will last out in the weather.So far its enough to get my 15 yr old out into the shop and wanting to build something, had a great day with him today.
mowarren wrote:yes its all resawn from used 2x6 and 2x4 and all done with the greenie I cleaned up this spring.The finish is spar urethane with uv protection so hopefully it will last out in the weather.So far its enough to get my 15 yr old out into the shop and wanting to build something, had a great day with him today.
Good for both of you!;)
Here's a free-standing pantry that I started months ago....finally put it in place today. It's 3' wide, 2' deep, and 7' tall White Ash. A very quick 'fast forward of the project'.....
Here's the starting point
[ATTACH]14346[/ATTACH]
A side panel
[ATTACH]14347[/ATTACH]
Basic box
[ATTACH]14348[/ATTACH]
Door config
[ATTACH]14349[/ATTACH]
Fixed shelf in the middle...the rest are adjustable
[ATTACH]14350[/ATTACH]
Bud F.
SS 500(09/1980), DC3300, jointer, bandsaw, belt sander, Strip Sander, drum sanders,molder, dado, biscuit joiner, universal lathe tool rest, Oneway talon chuck, router bits & chucks and a De Walt 735 planer,a #5,#6, block planes. ALL in a 100 square foot shop. .
