A Slow Boat To Nowhere
shipwright
Re: A Slow Boat To Nowhere
Post by shipwright »
It would be what boat builders call a "fashioned" piece, meaning basically that you would do your joinery with an oversized block and then sculpt it to fair in with the desired appearance.
If I were doing it I guess I'd choose a stepped scarf joint (traditional for this type of joint) and glue up a block with alternating grain directions to fashion the pieces from. .......sounds harder than it is.
algale
Post by algale »
shipwright wrote:It would be what boat builders call a "fashioned" piece, meaning basically that you would do your joinery with an oversized block and then sculpt it to fair in with the desired appearance.
It sounds really, really hard! Plus, if I can't see it....
shipwright
Sorry for the Q&D sketch.
algale
Post by algale »
Thanks for the sketch, it is self-explanatory. I like the idea a lot. Making up the blank would be a breeze. Fitting it and making the joints looks like it could tax my limited hand tool skills! Let me think about it. It might even be something I add over the winter.
edflorence
Post by edflorence »
algale wrote:Incredibly, the construction phase is OVER.
Well deserved congratulations!
and, fwiw, my vote is in favor of the pipe holes.
Idaho Panhandle
algale
Post by algale »
Thanks, Ed!
rjent
Post by rjent »
do you have enough time to splash before it really gets cold?
BTW, you will smile every time you paddle this beauty on the water.
I must say, that I hope to have half your woodworking abilities before I am done.
That is a beautiful boat and a beautiful job making it ..... :cool:
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
algale
Post by algale »
rjent wrote:do you have enough time to splash before it really gets cold?
It's looking doubtful for a launch before spring. I have a lot of varnishing to do and it really needs a couple of weeks to fully harden. Canoeing in Maryland in December isn't anyone's idea of a fun time. But, I am hoping for major temporary Global Warming! (That's a joke people -- no political screeds, please!).
I have learned a lot making this canoe, but I will let you in on a dirty little secret: It does not require any major woodworking skills -- lucky for me because I don't have any such skills. It does require a little patience and a LOT of sanding. :D
algale
Post by algale »
Got a few more coats on the decks/gunwales and a new one in the interior (interior already had 2 coats but had to sand back quite a bit to get rid of the worst drips). It isn't perfect by any means but I think it is good enough.
Once these are dry, I'll flip it and work on the outside. So close!
algale
Post by algale »
Notice anything different? :rolleyes:
So much easier varnishing the outside! One down, at least one more to go.
