Re: My Growth Rings with Scott Markwood
I agree with Tom on this subject. I guess I never saw it written down anywhere to leave some space for the spring to compress but I had some prior familiarity with elastomeric couplings and assumed it was necessary. The vibration feedback through the coupler can be a problem when there's a stiff connection between the hubs. The material is strong enough to withstand it though, along with any withstanding flexing necessary to account for misalignment of the hubs.
Since there aren't widespread reports of couplers breaking and I'm sure plenty of people who jam those things in as tight as possible then in the end it doesn't seem to matter much. Those couplers are tough.
I posted this on the Shopsmith woodworkers welcome group on facebook: "It's a interesting notion. It would defiantly keep the spring from being completely collapsed, and not loosing full rebound over time."
Chad Nevels
1963 Shopsmith Mark V "Goldie" 1-1/8 hp Serial # 379185
1980 Shopsmith Mark V 500
1994 Shopsmith Mark V 510
1994 OKUMA LB15 II OSP7000
2017 OKUMA LB3000 EXII SPACE TURN MY OSP P300LA
The inside end of the spring is recessed inside the shaft of the coupler at least 1/2". Even if the hub is bottomed in the coupler the spring is only compressed about half way.
Thanks, John.
Chad Nevels
Tom is certainly entitled to his opinion and he clearly stated it was his opinion in the video.edma194 wrote: ↑Sat Mar 26, 2022 4:57 pm I agree with Tom on this subject. I guess I never saw it written down anywhere to leave some space for the spring to compress but I had some prior familiarity with elastomeric couplings and assumed it was necessary. The vibration feedback through the coupler can be a problem when there's a stiff connection between the hubs. The material is strong enough to withstand it though, along with any withstanding flexing necessary to account for misalignment of the hubs.
However, I found it interesting he used his power station instead of his MK V to make his point. He clearly needs to adjust the lock on his power station. Mine is not overly tight to lock and the back and forth movement of my jig saw mounted is barely enough to feel let alone see. On my MK 7 (upgraded MK V 520) there is no movement at all.
jsburger wrote: ↑Sat Mar 26, 2022 5:48 pmTom is certainly entitled to his opinion and he clearly stated it was his opinion in the video. I am sucribed to Tom's channel and he is spot on with his videos.edma194 wrote: ↑Sat Mar 26, 2022 4:57 pm I agree with Tom on this subject. I guess I never saw it written down anywhere to leave some space for the spring to compress but I had some prior familiarity with elastomeric couplings and assumed it was necessary. The vibration feedback through the coupler can be a problem when there's a stiff connection between the hubs. The material is strong enough to withstand it though, along with any withstanding flexing necessary to account for misalignment of the hubs.
Tom is certainly entitled to his opinion and he clearly stated it was his opinion in the video. I am subscribed to Tom's channel and he is spot on with his videos.edma194 wrote: ↑Sat Mar 26, 2022 4:57 pm I agree with Tom on this subject. I guess I never saw it written down anywhere to leave some space for the spring to compress but I had some prior familiarity with elastomeric couplings and assumed it was necessary. The vibration feedback through the coupler can be a problem when there's a stiff connection between the hubs. The material is strong enough to withstand it though, along with any withstanding flexing necessary to account for misalignment of the hubs.
Third time the charm?
BTW the spt mount on the power station is always sloppy.
Some time it takes more than once.
Well my power station is not anywhere near as sloppy as Tom's. Not even close.
Maybe he 'cheated' and did not secure the slide.
