Main Table Alignment
Re: Main Table Alignment
That is the method that was being taught back when Ifirst acquired a Shopsmith., IT WORKS. If the dowel (I use a long allen wrench) remains in near contact with the blade the miter track is parallel to the blade.
Two lines (surfaces) at all points equal distant are said to be parallel. The miter track is equal distance from the blade.
Hobbyman2 wrote:I might be wrong but I believe I seen a video once where the guy put his allen wrench ,,,,,or a rod ,,or even a dowel ,,in the hole in the side of the miter gage,,tightened down the set screw and used it as a reference when aligning the table ?
I tried it once and I still check and adjust the fence just to be sure I am ok.
Hobbyman2
That is SOP from waaaaay back. :cool:
