Hot water will remove 'most' of the label glue, and goo gone will remove what is 'left'. Clear tape is likely more time efficient!;)reible wrote:Yes that is a jif jar. I too have many of them in use as storage containers and have more coming every few months. The stick part were the label comes off then new jars is solved by putting a clear packing tape over it.
The jar is there to hold all the mini clamps. Better then having to dig them out of the bottom of the case and easy to take to where I'll be using them.
Today in my shop (while making some shelves)
Shelves can be supported by a wall or suspended from above. I have even seen garage shelving units that are suspended hooks (or I bolts) and raised and lowered on cables or ropes. JimJPG40504 wrote:Shelf right angle brackets mounted to 'suspend' the shelf from above, rather than support it from below the shelf????
F. Jim Parks
Lakewood, Colorado:)
