My new business venture
RFGuy
Re: My new business venture
Post by RFGuy »
One other thought is changing out the threaded insert for a metric equivalent. Potential customers outside of US will want this.
πŸ“ΆRF Guy
Porter Cable 12" Compound Miter Saw | Rikon 8" Low Speed Bench Grinder w/CBN wheels | Jessem Clear-Cut TSβ„’ Stock Guides
RFGuy wrote: ↑Tue Apr 13, 2021 10:42 pm One other thought is changing out the threaded insert for a metric equivalent. Potential customers outside of US will want this.
Yes indeed! By design, I can install M6 x 1 mm inserts in the exact same sliding-nut bodies. :)
BuckeyeDennis wrote: ↑Tue Apr 13, 2021 10:38 pm
And one other thing that Shopsmith afficionados will appreciate: all WoodAnchor fasteners use 5/32” hex drives. :cool:
The result of using 1/4-20 BUTTON head socket screws. ;)
β•ŸJPG β•’
β•šβ•β•β•β•
JPG wrote: ↑Wed Apr 14, 2021 9:20 am
Bingo! And also true of 1/4"-20 flat-head screws.
rjent
Post by rjent »
Plus (I though I would add ;) ) the 1/4 20 button head bolts using the aforementioned 5/16 Allen wrench, screws right into the ShopSmith sliding t-nuts for the slots of the 520 fence/table system. Lets you add all kinds of utility to the 520 system in general.
Just 2 more cents :D
Dick
1965 Mark VII S/N 407684
1950 10 ER S/N ER 39671
1951 jigsaw X 2
1951 !0 ER #3 in rebuild
rjent wrote: ↑Sun Apr 18, 2021 3:24 pm Plus (I though I would add ;) ) the 1/4 20 button head bolts using the aforementioned 5/16 Allen wrench, screws right into the ShopSmith sliding t-nuts for the slots of the 520 fence/table system. Lets you add all kinds of utility to the 520 system in general.
2 cents and an extra 5/32" :D ;)
Stand by for another 5/32 "screw". [5/16-18 low height socket head cap screw]
β•ŸJPG β•’
β•šβ•β•β•β•
JPG wrote: ↑Sun Apr 18, 2021 4:23 pm
Not to mention standard 5/16”-18 and 5/16”-24 set screws. :)
roy_okc
Post by roy_okc »
I received mine today, a day to spare for the promised June delivery. These are quality items. The "nuts" feel substantial in the hand, heavier than it looks like it should be. The flashing line is minimal, maybe a couple thou and not sharp, just enough to feel. The brass inserts are smooth on the included stainless steel button head screws as well as some nylon bolts that I have. I can't yet say what the router bit is like, but since it is a Whiteside, I trust that it will live up to the quality I've had with others of that brand. The packaging was good, shipping was quick.
Roy
CNCed G0704 milling machine
Laser engraver
The minimal 'flash' is on non-functional surfaces.
β•ŸJPG β•’
β•šβ•β•β•β•
DLB
Post by DLB »
I'm curious to know how others intend to use the router bit. I usually take multiple light passes when routing, so I'm thinking cut a deep dado first in multiple passes then cut the rest of the WoodAnchor contour in one pass. Is that the right approach here? Or cut it all at once with a slow feed rate? (Seems like the chips would become a problem.) Or other?
