Painting Goldie / Brownie
mmorris wrote:I'm about to the point of painting my greenie. I've searched "Painting" and did not come up with definitive answers to the questions below. I've stripped mine down to bare aluminum/metal and am going to use self-etching primer.
For those of you that have used Hammered paint and have a few years use on the paint job, did you sand/prep before painting and between coats? Did you use a sealer/topcoat/clearcoat?
Thanks, Monte (sorry if this got posted twice:)
You can delete one of them as long as it wasn't the "start of a thread".
heathicus
Post by heathicus »
JPG, in your "group portrait" above, what is the part on the lower right?
mmoris, I did not sand between coats of the Hammered. Since you want a texture instead of a smooth surface (otherwise, why use hammered paint?) I don't think sanding is necessary. But I'm not sure what what the effect would be if you did sand between coats. I did use a clear coat on my second ER and on the legs of my Mark 5. I think it made a difference. I have nicks and dings in the paint on my first ER and on the parts where I didn't use a clear coat on the Mark 5. I don't have such nicks and dings in the paint where I used a clear coat. The Hammered paint does become pretty hard, it just takes a month or so to fully cure to that hardness.
Heath
Central Louisiana
SDSSmith
Post by SDSSmith »
heathicus wrote:JPG, in your "group portrait" above, what is the part on the lower right?
Belt sander base casting.
Rob in San Diego
Think 6" Belt Sander.;)
Sorry Rob, I posted this before going to 'page two'!
mmorris
Post by mmorris »
Thanks, Heath.
Did you sand before you primed (if you primed)?
Did you wait for a month until the paint completely hardened, to apply the clear coat?
Monte in Missouri
Two 1954 Mark V's: #268502 and #267199
I have done no sanding either before primer, or in between any coats. I have gone all the way to bare metal and then self etching primer as well as simply painting over existing paint.
It is necessary to make sure the workpiece is cleaned.(no wax/oil/dirt/rust)
The bare metal/primer will require more than one coat.
The hammer tone 'effect' will not occur in a breezy environment. The differing parts of the hammertone paint MUST separate after application to the workpiece to create the hammertone effect.
The separation works best if the freshly painted surface is horizontal for a brief period(coupla minutes) while the 'effect' is being created.
Another reason for a brief horizontal positioning is that there is a very fine line between 'heavy enough' to allow 'effect' and running.
Fortunately this paint covers over quite well, and a botched result can be either touched up, or simply painted over with an additional 'coat'.
Since it is a heavy coat, it can be 'tackey' for a while. Leaving in the sun for a couple of hours helps immensely.
If you are going to attach screws, make sure it is really really dry.
Heath's next post reminded me that I neglected to say to let it dry before 'additional' coat.
heathicus
Post by heathicus »
mmorris wrote:Thanks, Heath.
On my ER's I did not sand. But those were cast iron parts with an already textured surface. I cleaned them up with a wire brush on my angle grinder, then wiped with acetone before painting.
On the aluminum surfaces of the Mark 5, if I recollect correctly, I sanded the stamped steel parts (legs, motor pan, and belt cover) but just used a brass wire wheel on the aluminum parts when necessary (sometimes just a 3M paint stripping pad and a little acetone was all that was necessary). This was after paint removal with CitruStrip. And I always wiped with acetone before painting.
I followed the directions on the can before applying a second or clear coat. I can't recall what they are, but I *think* you're supposed to wait 48 hours before applying another coat.
Since you're going for a textured finish and not a slick automobile type finish, initial sanding and sanding between coats is not necessary. Just follow the directions on the can and you'll be fine.
Heath
Central Louisiana
billmayo
Post by billmayo »
JPG40504 wrote:I have done no sanding either before primer, or in between any coats. I have gone all the way to bare metal and then self etching primer as well as simply painting over existing paint.
Excellant suggestions for painting with Hammered paint. To obtain a faster drying time when using the Rustoleum Hammered paint, I put the painted headstock/parts in my converted Power Coating range oven at 200 deg. max. for 1 to 2 hours. This made a hard surface that I was able to wax/shine and then assemble the headstock immediately. This does not work for regular spray can paints (burns them), only for the Hammered version.
Of course, I wouold recommend trying this with some small part first to see what the results will be before trying a headstock.
billmayo wrote:. . .
Been thinking of using kitchen oven, but did not know about temperature. THANK YOU!
Not recommended when SWMBO is either home or about to return soon!:eek:
mmorris
Post by mmorris »
Thank you all for the info!
Monte in Missouri
