3" caster upgrade
Re: 3" caster upgrade
dusty wrote: Sun Mar 05, 2023 3:53 pm
jsburger wrote: Sun Mar 05, 2023 3:10 pm So back when the paper template became a problem was that with the castor wheel kit and they fixed that with the metal template but never fixed the castor assembly kit. Or SS never photo copied the templet for the complete castor kit. It is all kind of strange. The left hand doesn't know what the right hand is doing.
I can't tell you when but I can assure you that the paper template was at some time corrected. I had one of the bad photocopies; unfortunately, I must not have kept it. I received a correct copy from SC and still have it. I took measurements from that copy to make my wooden template. Unfortunately, I did not keep that either. Now I have two sets of wheels to mount. and only a paper template.
Incidently, this photo copy SNAFU was a long time ago. Must we drag up this sort thing for extended discussion on the forum.
Yes it was but, the OP said he had a problem with the paper copy of the templet so...
jsburger wrote: Sun Mar 05, 2023 3:59 pm
He also said the error was on the order of 1/8" and that was not typical of the photo copy issue. That sounds more like something that would go wrong in my shop.
OK, I don't remember what the original error was so I defer to you.
