SketchUp 101
mbcabinetmaker
Man if school had been this much fun I would be a lot smarter today!:D
[ATTACH]5339[/ATTACH]
There is still time to catch up if anyone would like to join the class.
- Lesson 4.jpg (41.97 KiB) Viewed 4199 times
Mark
2017 Power Pro Mark 7
Mark
mbcabinetmaker
- tom_k/mo
Check THISout... Sorry, didn't get the sound with this vid, but one is with the Dimension tool and the other is manually typing in dimension with Text tool (and I typed it in wrong too)shydragon wrote:How do you dimension diameters? I found something for angular dimensions.
Thanks, without the sound, I had to play it over several times. Finally, I realized I had to edit the group in order to pick that feature. Worked like a charm.
Pat
Oregon
1992 SS 510, 11" Bandsaw on power station, 4" jointer, Pro Planer, Incra Miter 2000, Incra Ultimate Fence Router Pkg, Grizzly 6" Parallelogram Jointer.
Oregon
- tom_k/mo
The next lesson is now available. This lesson re-enforces the construction techniques learned before, shows how to build and use your own custom components, uses Follow-Me to create routings, and the Intersect function to help define complex shapes easily.
- Lesson 5 - Construction of a Stile/Rail framed Raised Panel cabinet door.
In lesson 5, Under Stile Construction, your telling us to "Click on the Molding Shape Rail". Watching the video, it is the Stile, which made more sense. I generally try to follow your written instructions 1st, and if I run into trouble, I watch the video.
Pat
Oregon
Oregon
- tom_k/mo
Thanks, think I got it fixed.
